I need help.
Could someone help me write a script that changes the summary of another issue.
I have in a customfield the KEY of this issue that I want to change.
import com.atlassian.jira.issue.IssueManager;
import com.atlassian.jira.issue.CustomFieldManager;
import com.atlassian.jira.component.ComponentAccessor;
def id_vaga = customFieldManager.getCustomFieldObject("customfield_16057")
def key_value = issue.getCustomFieldValue(id_vaga).toString()
def issueManager = ComponentAccessor.getIssueManager()
def issue1 = issueManager.getIssueObject("${key_value}")
issue1.setSummary("XYZ")
It depends where you add your post function. You could try also this one
IssueManager im = ComponentAccessor.getIssueManager();
MutableIssue issue = im.getIssueObject(key_value);
issue.setSummary("XYZ");
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
ComponentAccessor.getIssueManager().updateIssue(user, issue, EventDispatchOption.ISSUE_UPDATED, false)
tks @Alexey Matveev for your response!
But I'm getting the same error as I reported in the comment above.
It is a static error. If you run the script, the script would work. Or You could write like this:
MutableIssue issue = im.getIssueObject(key_value) as MutableIssue;
I solved the problem by adding the lines below:
But this signaling me another mistake
Even though I save and trying to execute the transition, the summary of the other issue is not changed (and this error appears in the log)
2018-05-30 08:54:46,492 ERROR [workflow.ScriptWorkflowFunction]: ************************************************************************************* 2018-05-30 08:54:46,492 ERROR [workflow.ScriptWorkflowFunction]: Script function failed on issue: RH-118, actionId: 111, file: <inline script> groovy.lang.MissingPropertyException: No such property: EventDispatchOption for class: Script1725 at Script1725.run(Script1725.groovy:15)
Try like this:
Try this one
Tks @Tuncay Senturk _Snapbytes_ for your response!
I'm getting this error message when trying to save the script.
JIRA 7.1.7
I want to use this script in post function.
