I have a scripted field for the date issue was last changed to to Closed status, Search Template is set to Date Time Range picker.
Could this scripted field be used in JQL dateCompare function.
JIRA: 6.4.12
Script Runner: 3.1.4
Hi - It is not possible to use scripted field in JQL dateCompare function as far as I know. The underlying reason is very similar to the issue : https://productsupport.adaptavist.com/browse/SRJIRA-611
I will update you If I come across any solution.
