Scripted Field generates Cannot invoke method getCustomFieldValue() on null object
AndreH
I have 2 separate Scripted Fields on a Sub-task. These fields are reading existing data from a custom field on the parent issue.
Field 1 on Sub-task (Parent Prod Start Date). This field reads a custom date field from the parent issue and displays it on the sub-task.
Field 2 on Sub-Tasks (Parent DBA Estimate). This field reads a custom numeric field from the parent issue and displays it on the sub-task.
Both of these scripted fields is generating errors in the logs during a re-indexing and also when a user is working on a parent issue.
error - javax.script.ScriptException: java.lang.NullPointerException: Cannot invoke method getCustomFieldValue() on null object. A stacktrace has been logged.
Here is the code for Parent Prod Start Date -
import com.atlassian.jira.issue.Issue;
import com.atlassian.jira.ComponentManager;
import com.atlassian.jira.issue.CustomFieldManager;
import com.atlassian.jira.issue.fields.CustomField;
import com.atlassian.jira.component.ComponentAccessor;
def field = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("Prod Install Start Date/Time")
def abc456 = issue.parentObject.getCustomFieldValue(field);
return abc456;
Here is the code for Parent DBA Estimate -
def field = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("DBA Estimate")
def abc123 = issue.parentObject.getCustomFieldValue(field);
return abc123;
Here is the complete error -
2014-08-05 08:45:32,448 ajp-bio-8009-exec-17 ERROR ahughes 525x6851x1 vihicd 1.1.1.1 /plugins/servlet/com.onresolve.ScriptedFieldPreviewServlet [onresolve.jira.groovy.GroovyCustomField] javax.script.ScriptException: java.lang.NullPointerException: Cannot invoke method getCustomFieldValue() on null object
JamieA
August 4, 2014
Nic is correct as usual, but I don't think that's the problem.
I did a quick test and it seems like jira requests the value of the custom field even when it's not in the context. I don't know why... I think there is a reported bug for this in jamieechlin.atlassian.net/browse/GRV but it's not fixed, because I'm not sure what I can do. I need to reproduce and report to Atlassian.
In the meantime I would do:
if (issue.isSubTask()) {
return something
return null
Nic Brough -Adaptavist-
August 4, 2014
This can happen when either
  1. The field you are trying to read has no data
  2. The field you are trying to read is not valid for that project/issuetype
In both cases, wrapping the "getCustomFieldObject" call in "if field not null" type if blocks should fix it.
AndreH
Hi Nic,
I am not able to get the logic correct for checking against the "if field not null". Do you have an example of the syntax?
August 4, 2014
Argh, sorry, I've made a mistake
Most of your code is actually ok, and, for the record, this is what I do to avoid empty field errors:
CustomField budgetField = customFieldManager.getCustomFieldObjectByName(budgetFieldName);
def thisPaidCR = issue.getCustomFieldValue(paidDaysField)
  if ( thisPaidCR )
    total += thisPaidCR
But although that will catch the error I thought you're getting, I have looked in the wrong place.
You have:
The problem is not "getCustomFieldValue", it's "parentObject". That is returning a null.
AndreH
Yes, it is on the parent object where the null error is coming.
i tried to verify there is a valid field on the parent, however it is still generating the same issue.
Here is the new code, that still doesn't work
def total = "Hello";
if (abc456 != null)
total = (abc456)
return total;
August 4, 2014
Ok, I have a thought - could you try
def abc456 = issue.parentObject().getCustomFieldValue(field);
I think parentObject is a method, not a field, so we need ()
p.s. I still apologise for looking in completely the wrong place at first, I feel like I owe you a pint or something to make up for wasting your time!
AndreH
I tried -
def abc456 = issue.getParentObject().getCustomFieldValue(field);
return abc456
return null;
however it is still not working for the parent issue
August 4, 2014
I'm not sure it can work for the parent issue - by definition, they won't have a parent themselves, and, if I have understood your config, they won't have the field either. I'd move the "def abc456" inside the "if (issue.isSubTask())" block, then it won't try to retreive the parent or the field when there's nothing there.
AndreH
Thank you!
moving that in seems to have taken care of the error -
field = ComponentAccessor.getCustomFieldManager().getCustomFieldObject('customfield_11401')
return abc456
return null;
