Scripted Field to display Original Estimate Change history
Matthew Beda
import com.atlassian.jira.component.ComponentAccessor
import com.atlassian.jira.issue.history.ChangeItemBean
import com.atlassian.core.util.DateUtils
def changeHistoryManager = ComponentAccessor.getChangeHistoryManager()
def string = "<table class='aui aui-table-list'><thead><tr><th>From</th><th>To</th><th>On Date</th></tr></thead><tbody>"
List<Long> rt = [0L]
def origestimate = changeHistoryManager.getChangeItemsForField(issue, "timeoriginalestimate")
if (origestimate.size() <= 0){
string = "N/A"
} else {
origestimate.each {
ChangeItemBean item ->
def totalf = item.fromString as Long
def FROMSTRING = (totalf / 3600)
def totalt = item.toString as Long
def TOSTRING = (totalt / 3600)
def createdDate = item.created.format('yyyy/MM/dd')
string += "<tr class='aui-row-subtle'><td>"+ FROMSTRING + "h</td><td>"+ TOSTRING +"h</td><td>"+createdDate+"</td></tr>"
string += "</tbody></table>"
return string
Matthew Beda
See above
