Scripted Field to return linked issues
Pete Singleton
November 3, 2021 edited
I am attempting to script a custom field (via ScriptRunner) to return all linked, dependent issues.  It seems to work when I test it in the ScriptRunner console, but doesn't render correctly on the issue screen or search results.
Here is the script:
import com.atlassian.jira.issue.IssueManager
import groovy.xml.MarkupBuilder
import com.atlassian.jira.config.properties.APKeys
def baseUrl = ComponentAccessor.getApplicationProperties().getString("jira.baseurl");
def issueLinkManager = ComponentAccessor.getIssueLinkManager()
def issueManager = ComponentAccessor.getIssueManager()
def outwardIssueLinks = issueLinkManager.getOutwardLinks(issue.getId())
def inwardIssueLinks = issueLinkManager.getInwardLinks(issue.getId())
def subOutwardElements = outwardIssueLinks.findAll { it.issueLinkType.name == ("Dependent") }
def subInwardElements = inwardIssueLinks.findAll { it.issueLinkType.name == ("Blocks")}
def issuelist = []
assert issuelist.empty
if (subOutwardElements.size() > 0) {
  for (def i = 0; i < subOutwardElements.size(); i++ ) {
  def dependIssue = issueManager.getIssueObject(subOutwardElements[i].destinationId)
  issuelist.add(dependIssue)
if (subInwardElements.size() > 0) {
  for (def i = 0; i < subInwardElements.size(); i++ ) {
  def dependIssue = issueManager.getIssueObject(subInwardElements[i].sourceId)
return issuelist
When I select "preview" to test it on an issue is shows this:
However, on the issue screens it shows:
$issuePickerViewRenderer.getIssuePickerHtml($value)
Pete Singleton
November 8, 2021
Thanks for confirming the script works.  I've got it working now by changing the default Searcher for the field to "Issue Key Searcher".  It defaulted to Free Text.  All working now!
Christoph Beer December 6, 2021
Thanks. This was the hint I was missing too.
Like Antoine Berry likes this
Antoine Berry
Hi @Pete Singleton ,
I just tried your script and it is working fine. Are you sure that the field is on a the view issue screen, and that the issues are linked by a "Dependent" or "Blocks" link ?
Learn more
