Scripted Fields - Upgrade to Jira 6.2.2 breaks existing Crowd API statements
AndreH
I am currently testing an upgrade from Jira 5.2.7 to Jira 6.2.2
In the jira 5.2.7 we have several scripted fields that ready the Jira Users Account Properties meta-data and displays it in a Scripted Field on a issue.
For Example - in the user account - Jira User. Defined property (Manager - John Doe)
Here is the currently working Jira 5.2.7 scripted field -
import com.atlassian.crowd.embedded.api.User;
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.user.UserPropertyManager;
UserPropertyManager userPropertyManager = ComponentAccessor.getUserPropertyManager();
String propKey = "public Manager";
String propValue = null;
User u = getCustomFieldValue('Customer')
if (u) {
propValue = userPropertyManager.getPropertySet(u)?.getString('jira.meta.'+propKey);
return propValue;
Now, when I upgraded Jira to 6.2.2, this field no longer works and returns an error -
javax.script.ScriptException: org.codehaus.groovy.runtime.typehandling.GroovyCastException: Cannot cast object 'ahughes(ahughes)' with class 'com.atlassian.jira.user.DelegatingApplicationUser' to class 'com.atlassian.crowd.embedded.api.User' A stacktrace has been logged.
Did Jira 6.2.2 change the Crowd API statement? Is there a 6.2.2 version that would work?
Thanks in advance,
Andre
JamieA
April 21, 2014
Something like this:
import com.atlassian.jira.user.ApplicationUsers
if (u) {
   def dirUser = ApplicationUsers.toDirectoryUser(u)
   then use dirUser not u
untested
AndreH
I tried changing it to the following -
import com.atlassian.jira.user.ApplicationUsers;
if (u) {
def dirUser = ApplicationUsers.toDirectoryUser(u);
then use dirUser not u;
return propValue;
However it still returns the error -
JamieA
April 21, 2014
Change
to
def u = getCustomFieldValue('Customer')
JamieA
April 21, 2014
"then use dirUser not u;"
was a comment for you not code.
To be more specific, change
to
propValue = userPropertyManager.getPropertySet(dirUser)?.getString('jira.meta.'+propKey);
AndreH
Thank you it worked - here is the final version -
if (u) {
return propValue;
