Scripted JQL - Issue ordering by date of comment from a specific user
Tsol
October 6, 2014
Hi everybody,
i am using Scripted JQL functions for searching issues commented by a specific user.
issueFunction in commented("by test after -7d")
Is it possible to get the results ordered by date of comment from the user i use in JQL?
I have tried some things without luck.
Thanx
JamieA
October 6, 2014
No easy way that I can think of. You could add a script field that returns the date of last comment (don't put on any screens) and order by that, but seems like overkill.
Or perhaps that function should by default return them in that order, although I don't know if jira's default ordering will override that.
Tsol
October 7, 2014
Thanks Jamie!
