Scripted default value in creation screen
Ireen Klein_Actonic
We use a custom field "Due Date". When an issue is created a default value should be set. It should be the current Date + 7d.
I have no programming skills, but we use scriptrunner. Somebody an idea?
Thank you very much for your advice!
Tansu Akdeniz
Hi @Ireen Klein_Actonic,
Follow the steps below;
  • Go to the related Workflow -> Create Transition -> Post-functions
  • Add new postfunction -> Script Runner postfunction -> Custom script
  • Paste the code
import java.sql.Timestamp
issue.setDueDate(new Timestamp((new Date() + 7).time))
Ireen Klein_Actonic
It should already be visible when the create issue screen is seen.
Ireen Klein_Actonic
I solved it now with Live Fields and the following script:
string Date=currentDate()+"7d";
if(argv["screen"]=="create") {
lfSet("Due Date",Date);
Register today
