I've created a scriptrunner scripted field that calculates a number value from the values in other fields on the issue.
The calculation is working correctly, and if I add the field to the view issue screen, I can see the value.
However, when I pull issues in a JQL query, the column for this field is blank and I can't figure out why.
My field type is: Scripted Field
My Template is: Number Field
My Searcher is: Number Searcher
I changed my return type to double, and it started working.
So, until I hear from an expert source or I find the docs myself, I'm going to assume that "Number Field" templated need to receive a Double =)
@Nic Brough -Adaptavist- - Is this normal with scriptrunner scripted fields?
Hi @padraik
Does the value appear when you display the ticket then reload the search ?
I think the issue is computed when you load the ticket, if you don' t and do a search it will have no data.
Regards
I wondered the same, but unfortunately that's not the fix -
To test, I opened this ticket first:
(all of the fields have values, but I erased all field values except for "Total Rank Score" before posting for privacy)
Total Rank Score is a bunch of 9's for this issue, and is expected behavior from my script.
After this, I execute the search as pictured below, and the "Total Rank Score" column displays as empty for all issues:
I have tried a re-index and the problem remains after.
I couldn't change the format in my original post. Here is my script:
import java.lang.Float
import com.atlassian.jira.issue.index.IssueIndexingService
def linkMgr = ComponentAccessor.issueLinkManager
def cfManager = ComponentAccessor.customFieldManager
def issueManager = ComponentAccessor.issueManager
def issueIndexingService = ComponentAccessor.getComponent(IssueIndexingService.class)
def thisIssue = issue as MutableIssue
log.warn("setting total rank score for " + thisIssue.getIssueType().getName() + " " + thisIssue.getKey())
def user = ComponentAccessor.jiraAuthenticationContext.loggedInUser
def iRankField = cfManager.getCustomFieldObjects(issue)?.find{it.name == "Initiative Rank"}
def iRankValue = issue.getCustomFieldValue(iRankField)
log.warn("initiative rank = " + iRankValue)
def eRankField = cfManager.getCustomFieldObjects(issue)?.find{it.name == "Epic Rank"}
def eRankValue = issue.getCustomFieldValue(eRankField)
log.warn("epic rank = " + eRankValue)
def fRankField = cfManager.getCustomFieldObjects(issue)?.find{it.name == "Feature Rank"}
def fRankValue = issue.getCustomFieldValue(fRankField)
log.warn("feature rank = " + fRankValue)
def totalRankScore = 9999999999
def iMultiplier = 100000
def eMultiplier = 10000
def fMultiplier = 1000
if(iRankValue && eRankValue && fRankValue)
totalRankScore = ((int)iRankValue*iMultiplier) + ((int)eRankValue*eMultiplier) + ((int)fRankValue*fMultiplier) as Float
log.warn("total rank score = " + totalRankScore)
else
log.warn("missing a rank value\n" + "total rank score = " + totalRankScore)
return totalRankScore
