Scripted post function to set a date value in custom field
Alex Christensen
May 12, 2015
I want to set a custom date field using a post function, but I only want to capture the current date if the field has not yet been set. I'd use a regular post function to do this, but once this field is populated, I don't want it to get overwritten, which is why I've turned to a script for this. I'm very new to groovy scripting and don't have much of a coding background - here's my attempt after looking at a lot of resources here on Answers and elsewhere.
import java.util.*
import com.atlassian.jira.ComponentManager
import com.atlassian.jira.CustomFieldManager
def customFieldManager = ComponentManager.getInstance().getCustomFieldManager()
def date = new Date()
Issue issue = issue
def funcDate = issue.getCustomFieldValue( customFieldManager.getCustomFieldObjectByName("Ready for Func Test") )
if (!funcDate) // if this field is empty, then the current date is set for this field
	issue.setCustomFieldValue("Ready for Func Test", date)
Basically, we want to be able to report on the date in which the issue was first transitioned to a particular status. I don't want to overwrite the value if the same transition is used again (which is very possible in our workflow setup). I've tried several variations of the code above, but I can't seem to get it to work the way I want it to. Even if the field is empty, the field does not get a value set to it during the transition for which I've configured this post function.
Is what I'm trying to do possible via a scripted post function? Am I at least close? smile Thanks for your help in advance!
4 votes
Alex Christensen
May 14, 2015
Found my answer using the answer in from a previous question here. Here's the final script I used:
import com.atlassian.jira.issue.CustomFieldManager
import static java.lang.Math.*
import java.sql.Timestamp
// get current issue
Issue issue = issue
// Getting custom field value
cfFuncDate = issue.getCustomFieldValue( customFieldManager.getCustomFieldObjectByName("Ready for Func Test") )
// Getting custom field object
cfoFuncDate = customFieldManager.getCustomFieldObjectByName("Ready for Func Test")
// get today's date
today = new java.sql.Timestamp(new Date().getTime())
// set value
if (!cfFuncDate)
	issue.setCustomFieldValue(cfoFuncDate, today)
Priyanka Khare
hello
@Alex Christensen will this run in JIRA cloud too?
Alex Christensen
August 23, 2018
I don't believe that it will. I don't have a Cloud instance to test this, but I don't think ScriptRunner on Jira Cloud allows you to configure scripted workflow post-functions.
Dave Furlani February 17, 2019
The above code gives me errors in the scripting window as soon as I paste it in - non declared variable, missing method and some other static review errors. I'm sure it is close but I'm very new to that language and the libraries/methods available.
Is there a working version of code to put today's date into a date field if it is empty?
Alex Christensen
February 19, 2019
@Dave Furlani this should probably work for you and stop throwing those non-declared variable errors.
def cfoFuncDate = customFieldManager.getCustomFieldObjectByName("Ready for Func Test")
def cfFuncDate = issue.getCustomFieldValue(cfoFuncDate)
// get today's date
def today = new java.sql.Timestamp(new Date().getTime())
// set value
if (!cfFuncDate) {
Dave Furlani February 19, 2019
Thanks, but I get a static check error on line 1 saying unable to resolve class com.atlassian.jira.ComponentAccessor.
The script could not be compiled: <pre>org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed: Script86.groovy: 1: unable to resolve class com.atlassian.jira.ComponentAccessor @ line 1, column 1. import com.atlassian.jira.ComponentAccessor ^ 1 error </pre>.
That's the only error though, which is an improvement on the script in the earlier posts.
So close.
Like Josef Zahlauer likes this
Alex Christensen
February 20, 2019
Oops, my bad. I fixed the script in my last post and it should no longer throw that error. :)
Dave Furlani February 21, 2019
Thanks Alex, that version worked perfectly.
You are a champ.
Alin Faur
Thanks a lot for sharing this script! It was exactly what I was looking for and it worked on the first try!
JamieA
May 12, 2015
Slight alteration:
def cfFuncDate = customFieldManager.getCustomFieldObjectByName("Ready for Func Test")
def funcDate = issue.getCustomFieldValue(cfFuncDate)
    issue.setCustomFieldValue(cfFuncDate, date)
Alex Christensen
May 12, 2015
Hi, Jamie - thanks for your help! Unfortunately, I made this alteration and the field still isn't populating. I double checked the name of the custom field to make sure I wasn't going crazy, too. :) Is there anything I need to do with the date format? JIRA presents the date as DD/MM/YY - if that's an issue from how Date() pulls the current date, how can I alter my code to populate the date in this format? Also, just to test, I took out my if statement to see if anything would write to that custom field anyway - I got the same result as before. The field is still empty.
JamieA
May 12, 2015
Where is the post-function in the list of post-functions? If towards the top, it should work. Can you find your atlassian-jira.log and see if there are any errors...
DevaKiran
Hi @JamieA ,
I have a Date Picker Field. I need a script to validate the Date which is <=now. If date is greater throw an exception
