I am trying to setup a behavior where if a user selects the value "IR Linked" for custom field "IR Evaluation" ("customfield_17007"), then an issue must be linked on that same Resolve transition screen. I.E Issue Links field is required. If any other value is selected, then an issue link is not required.
Also trying to force only two issue link types to be available: "Creates" or "Relates to"
I've been scouring the internet for answers, but the scripts I am putting together are duds. Help Needed! Thanks in advance.
Well there are a lot of incorrect getters and comparators in your example but you structured it in a good way so I decided to give it a shot. Took a little bit I'll give you that and I had to sort a few glitches to get it going, but alas I think this works..
My test includes just IR Evaluation and Linked Issues, no more no less. Other fields should not matter in this if you have more.
Mapped to project/issuetypes as needed
Guide workflow: the one you use for that issue type
Initializer: EMPTY
Conditions: When (Workflow Action: XX); where you select the transition you want this to work on
import com.atlassian.jira.issue.link.IssueLinkTypeManager
import com.onresolve.jira.groovy.user.FormField
FormField irEvaluationField = getFieldById(getFieldChanged())
FormField issueLinkTypesField = getFieldById('issuelinks-linktype')
FormField issuesField = getFieldById("issuelinks-issues")
if ("IR Linked".equals(irEvaluationField.getValue())) {
String[] allowedOutwardTypes = new String[]{"Creates", "Relates to"}
Map<String, String> allowedIssueLinkTypesMap = (Map<String, String>) ComponentAccessor.getComponent(IssueLinkTypeManager).getIssueLinkTypes(false).stream()
.filter(linkType -> allowedOutwardTypes.contains(linkType.getOutward()))
.reduce(new HashMap<String, String>(), (map, element) -> {
map.put(element.getOutward(), element.getOutward())
return map
(map1, map2) -> {
map1.putAll(map2)
return map1
issueLinkTypesField.setFieldOptions(allowedIssueLinkTypesMap)
issueLinkTypesField.setHidden(false)
issueLinkTypesField.setRequired(true)
if (((List) issuesField.getValue()).isEmpty())
issuesField.setError("You must link at least 1 issue.")
else
issuesField.clearError()
else {
issueLinkTypesField.setRequired(false)
issueLinkTypesField.setHidden(true)
FormField irEvaluationField = getFieldByName("IR Evaluation")
if ("IR Linked".equals(irEvaluationField.getValue()) && ((List) issuesField.getValue()).isEmpty()) {
else {
Why are there 2 fields? Normally, we could make this work with just one (the IR Evaluation). However, Linked Issues is kind of special and setting it as required doesn't work. While we can instead use 'setError()/clearError()' - which will prevent the transition - we still need to check that an issue has been added, but we cannot do this from the parent field, as at the time the IR Evaluation is set, we expect there not to be any issue at all, so we just can't go from here.
That is why we add the second field 'Linked Issues'. Luckily, when we add a linked issue, this triggers the behaviour. If it did not, I think we couldn't use behaviours at all and would have to use a workflow validator instead.
When a linked issue is added, the behaviour is triggered, and it simply checks if we still have the 'IR Evaluation' set and whether the changed issue count is greater than 0. If so, we're happy and can clearError(), if we haven't done anything or have removed any linked issue, we default back to setError() to prevent the transition.
One point I would mention is that I noticed you were hiding issue links when IR Evaluation was not IR Linked. So, in this script, as soon as you select IR Linked, it will permanently restrict the available issue link types. If you ever need issue links to work without IR Linked and contain all available link types (rather than just the 2), then it would need to be unbricked back, but I skipped it seeing as it wasn't needed for now.
Edit:
minor manual code cleanup, hopefully without typos, code block is pain in the neck and usually doesn't work..
fixed the 'TR Linked' 'IR Linked' mixup which is why this probably didn't work right out of the box
better explanation for the need of 2 fields
I think this is definitely on the right track, as I see the Linked Issues & Issue fields now have a red asterisk, when IR Evaluation = IR Linked. However, the Linked Issues field does not have any selections to chose from (Created or Relates to).
Any ideas?
I have validators setup through Jira natively on this same Resolve transition. Do all validators need to be run through Scriptrunner for this to execute properly?
@Radek Dostál - You're a legend for this. I had to make one slight modification, but otherwise what you provided works exactly how I had envisioned it. Thanks for your help on this.
Read the story
