Scriptrunner Behaviours on Label field
Vedant Kulkarni
Is it possible to apply Scriptrunner Behaviours on Label field?
My requirement is to copy Labels from one field to another while creating/editing issues that means on the form the second Label field should able to copy values from the first Label field.
Anyone can see the feasibility to apply this?
Andrew
June 9, 2019
Hi @Vedant Kulkarni ,
You can use workflow post function or listeners with event 'create'.
To copy value look here https://community.atlassian.com/t5/Jira-Core-questions/Copy-Custom-field-value-from-one-field-to-another/qaq-p/73207
B.R.
Vedant Kulkarni
Hi @Andrew
Thanks for the help.
I know using Post-function/Listener that can be possible but I want the second field should able to copy values on the form itself.
Andrew
June 10, 2019
Do you mean when user set field A to value valA, then on view form field B should be set to valA?
Maybe this https://community.atlassian.com/t5/Answers-Developer-Questions/JIRA-copy-field-value-to-another-field-with-JavaScript/qaq-p/522127
B.R.
Vedant Kulkarni
Thanks, @Andrew for sharing this. I followed the same way but this did not work for me. I think because of the Label field it will not work or I am not sure about this.
Is this will work with Label field?
