Scriptrunner - How to get attribute values from insight custom field with multi objects
Florian Schüller
Hi Community!
I try to get the attribute values from a multi user/multi object insight custom field.
I tried a lot, but i only get the attribute value from the first object. (the object which is alphabetic first)
I would like to get the attribute values comma seperated as result.
If someone could help me i would be very grateful :)
best regards,
Florian
This is the part, where i get the attribute value from the insight custom field (only the attribute from the first object):
Class objectFacadeClass = ComponentAccessor.getPluginAccessor().getClassLoader().findClass("com.riadalabs.jira.plugins.insight.channel.external.api.facade.ObjectFacade")
def objectFacade = ComponentAccessor.getOSGiComponentInstanceOfType(objectFacadeClass)
def cfManager = ComponentAccessor.getCustomFieldManager()
CustomField Benutzername = ComponentAccessor.getCustomFieldManager().getCustomFieldObject(11003) // ID von Customfield "Anfrage für"
def myValue = Benutzername.getValue(issue)
def myObjectBean = myValue[0]
def myAttrValue = objectFacade.loadObjectAttributeBean(myObjectBean.getId(), 1293).getObjectAttributeValueBeans()[0]; // ID von Attribute "Benutzername AD" vom Object Person
def myString = myAttrValue.getValue()
Alejandro Suárez García
Hi @Florian Schüller,
You can use this:
import com.atlassian.jira.issue.CustomFieldManager
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager()
CustomField Benutzername = customFieldManager.getCustomFieldObject(11003L) // ID von Customfield "Anfrage für"
ArrayList myValue = issue.getCustomFieldValue(Benutzername) as ArrayList
ArrayList myAttributes = []
myValue.each {
def myAttrValue = objectFacade.loadObjectAttributeBean(it.getId(), 1293).getObjectAttributeValueBeans()[0].getValue() // ID von Attribute "Benutzername AD" vom Object Person
myAttributes.add(myAttrValue)
log.warn myAttributes
Edit: I readed again your post. Here you go, the variable "myAttributes" have the attributes list comma separated.
Regards!
Florian Schüller
Thank you @Alejandro Suárez García
This works great!
Now i can use the variable for a DB Insert :)
Have a nice day.
best regards,
Florian
