Scriptrunner: Listener to set time estimates to a default value when they are not empty
Reno February 21, 2022
I am trying to set up a custom listener on issue creation that checks if the original and remaining estimates are empty, and in that case, set both to "1m".
I tried some solutions that I found in the community but I did not manage to get them working as expected.
Can anyone help me? What methods should I use to get and set both values?
Thank you in advance!
Deleted user February 21, 2022
Hi Reno,
The below code should work for your need.
Please also consider this answer as accepted if this is the solution you were looking for. That will make it more traceable for users in the future if they are facing the same issue.
import com.atlassian.jira.issue.IssueManager
import org.apache.log4j.Category
import com.atlassian.jira.bc.issue.IssueService
def Category log = Category.getInstance("com.onresolve.jira.groovy.PostFunction")
log.setLevel(org.apache.log4j.Level.DEBUG)
def loggedInUser = ComponentAccessor.jiraAuthenticationContext.loggedInUser
IssueManager im = ComponentAccessor.getIssueManager()
def issue = issue
//def issue = im.getIssueObject("ABR-39")
IssueService issueService = ComponentAccessor.getIssueService()
if (!issue.getEstimate() && !issue.getOriginalEstimate()){
def issueInputParameters = issueService.newIssueInputParameters()
issueInputParameters.setOriginalAndRemainingEstimate('1m','1m')
def updateValidationResult = issueService.validateUpdate(loggedInUser, issue.id, issueInputParameters)
if (updateValidationResult.isValid()) {
// Validate the update
def issueResult = issueService.update(loggedInUser, updateValidationResult)
//log.info(issue.getEstimate())
//log.info(issue.getOriginalEstimate())
//log.info(issue.getTimeSpent())
Aditya
Reno February 22, 2022
Thank you so much Aditya, it works as expected!
This is also very helpful to get me started with other scripts, since I am still struggling with the Jira API.
Like Deleted user likes this
