Scriptrunner- No such property: issue for class: com.atlassian.jira.event.issue.link.IssueLinkCreate
BarL October 26, 2019
I created a listener that runs on "IssueLinkCreatedEvent".
The listener works well but I keep getting this error on "def issue = event.issue as Issue" line:
2019-10-26 12:03:14,177 ERROR [runner.AbstractScriptListener]: Script function failed on event: com.atlassian.jira.event.issue.link.IssueLinkCreatedEvent, file: <inline script>
groovy.lang.MissingPropertyException: No such property: issue for class: com.atlassian.jira.event.issue.link.IssueLinkCreatedEvent
	at Script2068.run(Script2068.groovy:16)
	at com.onresolve.scriptrunner.runner.ScriptRunnerImpl.runScriptAndGetContext(ScriptRunnerImpl.groovy:178)
	at com.onresolve.scriptrunner.runner.ScriptRunner$runScriptAndGetContext$3.callCurrent(Unknown Source)
	at com.onresolve.scriptrunner.runner.ScriptRunnerImpl.runStringAsScript(ScriptRunnerImpl.groovy:167)
	at com.onresolve.scriptrunner.runner.ScriptRunner$runStringAsScript$2.call(Unknown Source)
	at com.onresolve.scriptrunner.canned.jira.workflow.listeners.CustomListener.doScript(CustomListener.groovy:123)
Part of my script:
import com.atlassian.jira.event.issue.IssueEventManager
import com.atlassian.jira.issue.ModifiedValue
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
import com.atlassian.jira.issue.link.IssueLinkManager
import com.atlassian.jira.issue.link.IssueLinkTypeManager
import com.atlassian.jira.event.issue.link.IssueLinkCreatedEvent
import com.atlassian.jira.event.issue.link.IssueLinkDeletedEvent
import org.apache.log4j.Level
import org.apache.log4j.Logger
  Does anyone know why?
Jack Nolddor _Sweet Bananas_
Hi, since IssueLinkCreatedEvent has not the method getIssue() you cannot use the line
during your script, please try the following instead as a base for your script:
def log = Logger.getLogger("com.nolddor")
log.setLevel(Level.DEBUG)
def sourceIssue = event.issueLink.sourceObject
def destinationIssue = event. issueLink.destinationObject
log.debug "An IssueLinkCreate event has been catched"
log.debug "Issue (from): ${sourceIssue.key}"
log.debug "Issue (to): ${destinationIssue.key}"
After creating a link the following traces should appear in the log file:
[...] /secure/LinkJiraIssue.jspa [com.nolddor] An IssueLinkCreate event has been catched
[...] /secure/LinkJiraIssue.jspa [com.nolddor] Issue (from): EMEA-920
[...] /secure/LinkJiraIssue.jspa [com.nolddor] Issue (to): LATAM-517
Hope this helps,
Regards
BarL October 27, 2019
Hi @Jack Nolddor _Sweet Bananas_  I wrote your code and did get :
2019-10-27 02:54:26,389 DEBUG [com.nolddor]: An IssueLinkCreate event has been catched
2019-10-27 02:54:26,390 DEBUG [com.nolddor]: Issue (from): PM-4847
2019-10-27 02:54:26,390 DEBUG [com.nolddor]: Issue (to): DOT-3940
 But now what?.. if I remove the  "issue = event.issue as Issue" line and replace it with your 2 liens I get a lot of errors on my whole script when it comes to the word "issue":
Error: The variable [issue] is undeclared.
Now you have to determine wich of two issues involved during the link need to be modified and replace your issue word with either sourceIssue if you want to perform your logic against PM-4847 issue or destinationIssue if you need to perform the modificationsn against DOT-3940 issue.
Regards
BarL November 18, 2019
@Jack Nolddor _Sweet Bananas_  Thanks! it works :) , maybe you can help me with one last thing -
In my code I update links that are connected to the same issue.
if (destinationIssue.getIssueType().getName() == "Defect" && responsibleTeamCfValue == "Sustaining") {
for (i in BundledEpics) {
if (i.getSummary().contains("Documentation")) {
DocTargetCF.updateValue(null, DocLinkedIssue, new ModifiedValue(DocLinkedIssue.getCustomFieldValue(DocTargetCF), i), new DefaultIssueChangeHolder())
if (i.getSummary().contains("Escalations")) {
EscalationTargetCF.updateValue(null, EscalationIssue, new ModifiedValue(EscalationIssue.getCustomFieldValue(EscalationTargetCF), i), new DefaultIssueChangeHolder())
The issue is that if I have two "Documentation" links, it only updates the first one.
Tuncay Senturk
Hi @BarL
IssueLinkCreatedEvent does not have Issue access directly as seen in the API here.
Because there are two issues that are linked.
You can get event.issueLink and then get Source and Destination issues as below
def issueLink = event.issueLink
def sourceIssue = issueLink.sourceObject
def destinationIssue = issueLink.destinationObject
I hope I was helpful
Hi @Tuncay Senturk  Thanks for responding.
When I add thous lines I get errors:
 For def issueLink = event.issueLink line I get Error: No Souch property: issueLink for class: com.atlassian.jira.event.issue.IssueEvent
For def sourceIssue = issueLink.sourceObject line I get Error: No souch property: sourceObject for class: java.lang.object
For def destinationIssue = issueLink.destinationObject line I get Error: No souch property: destinationObject for class: java.lang.object
Tuncay Senturk
Hi again,
You should remove
HI :)
Tried it..same errors.
Tuncay Senturk
Hi again,
Is it possible that you use same code for different event types?
For your first run you got below error:
As I mentioned for IssueLinkCreatedEvent you can get source and destination issues with the code I provided.
In the second run you got below error:
 issueLink property is not valid for IssueEvent, it is a property for IssueLinkCreatedEvent
if you use my code in IssueLinkCreatedEvent, you should not get "No Souch property: issueLink for class: com.atlassian.jira.event.issue.IssueEvent" error
I hope I was clear, if it was not clear, please let me know with the full code, then I will help.
BarL October 28, 2019
Hi thanks for helping me, I still get the same errors . I use only one event :"IssueLinkCreatedEvent". here is my full script with @Tuncay Senturk  code lines.
@Jack Nolddor _Sweet Bananas_  Tried your solution as well with no luck, when I removed the "def issue" line and replaced "issue" with "destinationIssue":
//def sourceIssue = event.issueLink.sourceObject
//def destinationIssue = event.issueLink.destinationObject
//def issue = event.destinationIssue as Issue
def currentUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def issueLinkManager = ComponentAccessor.getIssueLinkManager()
def issueManager = ComponentAccessor.getIssueManager()
def epicLinkCf = ComponentAccessor.getCustomFieldManager().getCustomFieldObject('customfield_10002')
def epicLinkCfValue = issue.getCustomFieldValue(epicLinkCf).toString()
def responsibleTeamCf = ComponentAccessor.getCustomFieldManager().getCustomFieldObject('customfield_14108')
def responsibleTeamCfValue = issue.getCustomFieldValue(responsibleTeamCf).toString()
def targetIssue = issueManager.getIssueObject(epicLinkCfValue)
// Find Bundle key of linked Defect Epic
def EpicBundleCf = ComponentAccessor.getCustomFieldManager().getCustomFieldObject('customfield_17004')
def EpicsBundleValue = targetIssue.getCustomFieldValue(EpicBundleCf).toString()
def DocumentationlinkName = 'Documentation Task'
def EscalationlinkName = 'Sustaining Link'
// Find the Defect's Documentation link issue
def DocLinkedIssue = ComponentAccessor.getIssueLinkManager().getLinkCollection(issue, currentUser).getInwardIssues(DocumentationlinkName)[0]
// Find the Defect's Escalation link issue
def EscalationIssue = ComponentAccessor.getIssueLinkManager().getLinkCollection(issue, currentUser).getInwardIssues(EscalationlinkName)[0]
def targetIssue3 = issueManager.getIssueObject(EpicsBundleValue)
// Get the Bundle epic's list
def BundledEpics = ComponentAccessor.getIssueLinkManager().getLinkCollection(targetIssue3, currentUser).getAllIssues()
final String epicLinkFieldName = "Epic Link"
def DocTargetCF = ComponentAccessor.customFieldManager.getCustomFieldObjects(DocLinkedIssue).findByName(epicLinkFieldName)
def EscalationTargetCF = ComponentAccessor.customFieldManager.getCustomFieldObjects(EscalationIssue).findByName(epicLinkFieldName)
try {
if (issue.getIssueType().getName() == "Defect" && responsibleTeamCfValue == "Sustaining") {
} catch (Exception exc) {
log.error("Link documentation and escalation issues to epic bundle : error: ", exc)
Tuncay Senturk
Most probably it is compile time error, you can add below line just after the import statements.
def event = event as IssueLinkCreatedEvent
Tuncay Senturk
It should look like below:
import ...
ALEXIS RODRIGUEZ
September 20, 2021
Hello @Tuncay Senturk
I'm new at ScriptRunner and trying to creating Listeners in ScriptRunner for Zephyr Scale Events (https://support.smartbear.com/zephyr-scale-server/docs/test-automation/integrations/creating-listeners-in-scriptrunner-for-events.html), specifically the one for when a Test Case y updated (https://library.adaptavist.com/entity/transition-an-issue-when-a-zephyr-scale-test-case-is-updated) and got this error:
Because:
"deprecated" because testCaseStatusModel (see line 19 of the script below) is null and i don't know why.
By the way, I configured the listener like this:
Then i modified my test case to DRAFT/DEPRECATED/APROVED but still same error.
