Scriptrunner Plugin Report Code for Jira
Damien Davis October 25, 2023
Adaptavist has this Confluence Macro to show User Installed Jira apps.
How would this need to be modified so that I could run it in the Script Console in Jira?
import com.atlassian.applinks.api.ApplicationLinkResponseHandler
import com.atlassian.applinks.api.ApplicationLinkService
import com.atlassian.applinks.api.application.jira.JiraApplicationType
import com.atlassian.confluence.xhtml.api.XhtmlContent
import com.atlassian.sal.api.component.ComponentLocator
import com.atlassian.sal.api.net.Request
import com.atlassian.sal.api.net.Response
import com.atlassian.sal.api.net.ResponseException
import groovy.json.JsonSlurper
import groovy.xml.MarkupBuilder
import groovyx.net.http.HTTPBuilder
import groovyx.net.http.HttpResponseException
import org.json.JSONObject
// Link to primary linked Jira instance
def appLinkService = ComponentLocator.getComponent(ApplicationLinkService)
def appLink = appLinkService.getPrimaryApplicationLink(JiraApplicationType)
def applicationLinkRequestFactory = appLink.createAuthenticatedRequestFactory()
// HTTP Request to Marketplace
def httpBuilder = new HTTPBuilder("https://marketplace.atlassian.com")
// Content access
def xhtmlContent = ComponentLocator.getComponent(XhtmlContent)
def writer = new StringWriter()
def builder = new MarkupBuilder(writer)
// Application Link check as per https://scriptrunner.adaptavist.com/latest/confluence/interacting-with-other-apps-via-applinks.html
def handler = new ApplicationLinkResponseHandler<Map>() {
@Override
Map credentialsRequired(Response response) throws ResponseException {
@Override
Map handle(Response response) throws ResponseException {
if (response.statusCode == 200) {
new JsonSlurper().parseText(response.responseBodyAsString) as Map
} else {
def req = applicationLinkRequestFactory.createRequest(Request.MethodType.GET, "rest/plugins/latest/")
def pluginListEndpoint = req.execute(handler)
def plugins = pluginListEndpoint["plugins"]
builder.table {
tbody {
tr {
th { p("App Name") }
th { p("Vendor") }
th { p("Installed Version") }
th { p("Status") }
th { p("License Type") }
th { p("Expiry Date") }
th { p("Marketplace Version") }
th { p("Description") }
plugins.each { plugin ->
if (plugin["userInstalled"] && !plugin["applicationPluginType"]) {
def encodedKey = URLEncoder.encode(plugin["key"].toString(), 'UTF-8')
def licenseRequest = applicationLinkRequestFactory.createRequest(Request.MethodType.GET, "rest/plugins/1.0/${encodedKey}-key/license")
def licenseData = licenseRequest.execute(handler)
def summaryRequest = applicationLinkRequestFactory.createRequest(Request.MethodType.GET, "rest/plugins/1.0/${encodedKey}-key/summary")
def summaryData = summaryRequest.execute(handler)
def addonsData
try {
addonsData = httpBuilder.get(
path: "/rest/latest/addons/${encodedKey}"
) as JSONObject
} catch (HttpResponseException ex) {
addonsData = new JSONObject("{}")
def latestVersionData
try {
latestVersionData = httpBuilder.get(
path: "/rest/latest/addons/${encodedKey}/versions/latest"
) as JSONObject
latestVersionData = new JSONObject("{}")
tr {
td { p(plugin["name"]) }
td { p(plugin["vendor"]["name"]) }
td { p(plugin["version"]) }
if (summaryData["enabled"].toString().contains("true")) {
td { p { "ac:emoticon"("ac:name": "tick") } }
} else {
td { p("") }
td { p(licenseData["licenseType"]) }
td { p(licenseData["expiryDateString"]) }
if (latestVersionData.has("name")) {
td { p(latestVersionData["name"]) }
} else {
td { p("") }
if (addonsData.has("summary")) {
td { p(addonsData["summary"]) }
} else {
td { p("") }
xhtmlContent.convertStorageToView(writer.toString(), context)
Register today
