Scriptrunner Scripted field to sum fields of child tasks
Wade Hephner August 30, 2018
Hello all, I have bee researching this and have not been able to find the answer.  I have a scripted field on a parent task and I would like to sum a field of all child tasks with a specific link type. I have gotten this far with my script but I cannot figure out how to return the value to populate the parent task field. Here is my script so far - the bold area is what i am pretty sure is incorrect to be able to return the results of the jql query.
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.issue.*;
import com.atlassian.jira.issue.search.SearchProvider
import com.atlassian.jira.jql.parser.JqlQueryParser
import com.atlassian.jira.web.bean.PagerFilter
def jqlQueryParser = ComponentAccessor.getComponent(JqlQueryParser)
def searchProvider = ComponentAccessor.getComponent(SearchProvider)
def issueManager = ComponentAccessor.getIssueManager()
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
// jql query to sum fields
def query = jqlQueryParser.parseQuery("issueFunction in hasLinks('is task of') AND issueFunction in aggregateExpression('Total Story Points', 'customfield_10209.sum()')")
//get results
def results = searchProvider.search(query, user, PagerFilter.getUnlimitedFilter())
return results
Thanks in advnace,
Wade
Mauricio Karas
September 3, 2018
Hello, Wade. Thanks for reaching out to the Atlassian Community!
I was able to achieve what you need with the following script without making JQL queries:
import com.atlassian.jira.config.SubTaskManager
SubTaskManager subTaskManager = ComponentAccessor.getSubTaskManager();
Collection subTasks = issue.getSubTaskObjects();
def customFieldManager = ComponentAccessor.getCustomFieldManager();
def customField = customFieldManager.getCustomFieldObjectByName("<Custom Field Name>");
def sum = 0;
for (currIssue in subTasks)
if (currIssue.getIssueType().name == "<Subtask Issue Type>")
sum += currIssue.getCustomFieldValue(customField) as int;
return sum
Just replace the "<Custom Field Name>" and "<Subtask Issue Type>" with the correct information and try the script.
MaurĂ­cio Karas
Wade Hephner September 4, 2018 edited
Thanks Mauricio Karas, this looks promising, however I am not selecting child tasks my issue type but by link type -- issueFunction in hasLinks('is task of') -- could that be plugged into the if statement?
Mauricio Karas
September 4, 2018
Yes, Wade. My bad, I misunderstood the question, I thought you were trying to get subtasks, but it's actually linked issues.
I was able to create the following script to get the linked issues:
import com.atlassian.jira.issue.link.IssueLink;
def sum = 0;
List<IssueLink> allOutIssueLink = ComponentAccessor.getIssueLinkManager().getOutwardLinks(issue.getId());
for (Iterator<IssueLink> outIterator = allOutIssueLink.iterator(); outIterator.hasNext();) {
IssueLink issueLink = (IssueLink) outIterator.next();
if(issueLink.getIssueLinkType().name == "Blocks"){
def linkedIssue = issueLink.getDestinationObject();
log.error(linkedIssue.getCustomFieldValue(customField));
sum += linkedIssue.getCustomFieldValue(customField) as int;
return sum
 In the "if" statement you need to compare with the outward link type, in my case "Blocks".
Let me know if this works for you.
MaurĂ­cio Karas
Mauricio Karas brilliant. works like a charm. thanks so much for the help.
Mark Markov
September 4, 2018
Hello @Wade Hephner
In case if this is subtasks, it is better to do without jql as @Mauricio Karas says
If issues links, you can do it like this
def customField = customFieldManager.getCustomFieldObjectsByName("FieldName").first()
def query = jqlQueryParser.parseQuery("worklogAuthor = admin")
//get results
def issues = results.getIssues()
def result = issues.collect {it.getCustomFieldValue(customField)}.sum()
return result
Just replace "FieldName" with field name that you want to sum
Hello Mark Markov, thanks for the reply. When I put this in I get null as the result. I have replaced "FieldName" with the field in the child task that I am trying to sum which right now should be 7.
Nidhi Gupta
Hello All, I used the code mentioned in the accepted answers to sum up the values from a custom field on the sub-tasks of type select list (single select). The aggregate will show up on the parent issue under a scripted field but I am getting following errors. Would appreciate any help to resolve this.
Learn more
