Scriptrunner Validator for cascading field to only apply to certain issue types on transition
Stephen Letch
January 16, 2019 edited
Hi
I've seen a bunch of examples with slightly different requirements. But my requirement is on a transition that 5 different issue types can go down, to only check two of them for BOTH levels of a cascading field to be filled in.
For example:
If Issue type = Service Request
then
Both levels of 'Service Request Type' cascading field need to be filled in
if Issue Type = Incident
then
Both levels of 'Incident Type' cascading field need to be filled in.
and to not worry about the other 3 issue types.
I managed to fish out this example from Googling around for the cascading field requirements, but I need to know how to how to make it only check depending on the issue type
def issue = issue as MutableIssue
def cascadingSelect = ComponentAccessor.customFieldManager.getCustomFieldObjects(issue)?.findByName("Service Request Type")
def values = issue.getCustomFieldValue(cascadingSelect) as HashMap
// Will return true if both the parent and child options in the Cascading Select have a value
values?.keySet()?.size() == 2
Stephen Letch
Hi
After a bunch of testing, this seems to only be paying attention to the first if statement, especially if I try and split it out to get two different error messages in the simple scripted validator.
It doesn't seem to be checking for your invalid input message
Tansu Akdeniz
Hi @Stephen Letch,
The following custom script validator may guide you;
import com.atlassian.jira.issue.CustomFieldManager;
import com.opensymphony.workflow.InvalidInputException
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager();
CustomField incidentTypeCF = customFieldManager.getCustomFieldObject("customfield_XXXXX");
if(issue.getIssueTypeId().equals("12345")){ // Incident Issue Type ID
if(issue.getCustomFieldValue(incidentTypeCF)?.values()*.value[0] == null
|| issue.getCustomFieldValue(incidentTypeCF)?.values()*.value[1] == null){
invalidInputException = new InvalidInputException("Please fill both cascading values..")
CustomField serviceRequestTypeCF = customFieldManager.getCustomFieldObject("customfield_XXXXX");
if(issue.getIssueTypeId().equals("54321")){ // Service Request Issue Type ID
if(issue.getCustomFieldValue(serviceRequestTypeCF)?.values()*.value[0] == null
|| issue.getCustomFieldValue(serviceRequestTypeCF)?.values()*.value[1] == null){
Stephen Letch
Getting errors on creation and also doesnt seem to stop the transition
CustomField incidentTypeCF = customFieldManager.getCustomFieldObject("customfield_11428");
if(issue.getIssueTypeId().equals("10103")){ // Incident Issue Type ID
 || issue.getCustomFieldValue(incidentTypeCF)?.values()*.value[1] == null){
CustomField serviceRequestTypeCF = customFieldManager.getCustomFieldObject("customfield_11417");
if(issue.getIssueTypeId().equals("10104")){ // Service Request Issue Type ID
 || issue.getCustomFieldValue(serviceRequestTypeCF)?.values()*.value[1] == null){
EEDIT: It worked when I changed
ccustomfield_11428 to Incident
EDIT 2: It doesn't seem to be paying attention to the invalidinput area and also if it s a simple scripted one it requires you to fill in the error field below anyway. If you use custom script so that it might use the invalidinput message then none of it blocks anything.
Think I'm going to split it up into two validators so it can show the separate messages depending on context, thanks very much though, this has helped a lot.
