Jira Version : 8.8.1
Scriptrunner Version : 6.37.0
I am trying to create a behavior within a transition where when users select a specific value in Resolution field it will hide the listed required fields and remove requirement.
However I the scripts I tried will only trigger upon loading of the transition screen.
Once I selected the expected values ie. Duplicate or Request Cancelled it does not update anymore.
I tried the following scripts.
~~Current saved script
def CField1= getFieldByName("Requestor Region")
def CField2= getFieldByName("Platform")
def TCType = getFieldByName("Resolution")
def selectedOption = TCType.getValue() as String
if(selectedOption=="Duplicate")
CField1.setHidden(true)
CField2.setHidden(true)
CField1.setRequired(false)
CField2.setRequired(false)
else if (selectedOption=="Request Cancelled")
else if (selectedOption!="Request Cancelled" || selectedOption!="Duplicate")
CField1.setHidden(false)
CField2.setHidden(false)
CField1.setRequired(true)
CField2.setRequired(true)
~~~Other scripts tried
Script 1 :
if (getActionName().equals("Setup Complete")) {
boolean hidden = (getFieldByName("Resolution")?.getValue()?.toString()?.equals("Duplicate"));
getFieldByName("Platform").setHidden(hidden);
Script 2:
import com.atlassian.jira.bc.project.component.ProjectComponent
import com.onresolve.jira.groovy.user.FieldBehaviours
import groovy.transform.BaseScript
@BaseScript FieldBehaviours behaviours
def platform = getFieldById('customfield_14524') //Platform
def components = getFieldById(getFieldChanged()).getValue() as List<ProjectComponent>
def compField = getFieldByName("Resolution")
compField.setAllowInlineEdit(false)
if (components.any {it.name.contains("Duplicate")}) {
platform.setHidden(false)
platform.setRequired(true)
else {
platform.setHidden(true)
platform.setRequired(false)
I have properly mapped the script since I am able to hide fields upon load upon testing.
I also tried via the initialiser function, nothing updates either.
Is there anything else I need to configure or something missing on my script?
Here are troubleshooting methods you can follow
Pramodh
Hi @Pramodh M
I tried switching with getFieldById, looks like I am getting null on this part(I got this via developer tools)
As for the logging output, I am having a hard time tracking error log.
I already enabled logging via com.onresolve.jira.groovy (DEBUG) but no entries were made when I went to the log file.
Is there another way to debug the script, like could I make a message prompt like in javascript, or somehow print a message in developer tools console?
