Scriptrunner behaviour: Using wildcards to find values
Dustin Glienke December 8, 2022
Hi there,
I'm trying to to set up a behaviour when a value contains a specific number:
def multiSelectField = getFieldById("customfield_164118");
def multiSelectFieldValue = multiSelectField.value as List
if (multiSelectFieldValue.contains(4000)) {
     wertcn.setFormValue("CN")
     wertus.setFormValue("US")
My value is Test_4000_test. Is there a way to use wildcards?
Alex Koxaras -Relational-
Hi @Dustin Glienke
Can you try instead of contains() the following?
matches("4000")
Hi Alex,
thx for replying quickly. Unfortunately I'm receiving the following error:
Is it possible to paste here you code so that I can perform some tests?
Yes of course:
import com.onresolve.jira.groovy.user.FieldBehaviours
import org.apache.log4j.Logger
import org.apache.log4j.Level
import groovy.transform.BaseScript
def material = getFieldById("customfield_164118");
def wertus = getFieldById("customfield_63900");
def wertcn = getFieldById("customfield_63901");
@BaseScript FieldBehaviours fieldBehaviours
def log = Logger.getLogger(getClass())
// If value is null
if (multiSelectFieldValue == [null]) {
else if (multiSelectFieldValue.contains(4000)) {
the field material is a multi select list. Test value is Test_4000_test
@Dustin Glienke just noticed on your script that on material you have this id:
customfield_164118
Is this correct? It has a six figure numerical id.
Yes it is correct:
Our system has a strange count system, we have not that many fields
Like • Alex Koxaras -Relational- likes this
@Dustin Glienke the following script worked for me:
def text = getFieldByName("Text field (akox)")
def multiSelectField = getFieldById(getFieldChanged())
def myValues =multiSelectFieldValue.toString()
def result = (myValues =~ /\d+/).findAll()
if (multiSelectFieldValue == [null] ) {
  else {
    assert result == ["4000"]
    text.setFormValue ("Found 4000")
  • The above script was placed on my multi select field. So this is were you place it.
  • You replace the text variable with your wertus and wertcn variables
  • You place your setFormValues below the "assert"
  • You delete my text variable
Let me know if that works out for you!
Unfortunately it does not work but i don't know why:
  else {
//text.setFormValue ("Found 4000")
Does anything happen or not?
Nothing happend
@Dustin Glienke did you try following the guidelines I gave you with code? This code works on my instance without any problem. What kind of fields are wertcn and wertus?
Dustin Glienke December 13, 2022
Hi Alex,
I found a solution. The function contains is the right one. I figured out to use this 'value' instead of "value". Now it is working. Thanks for your help!
def wertde = getFieldById("customfield_63902");
// If value is null
if (myValues.contains('4000')) {
if (myValues.contains('5000')){
if (myValues.contains('4000')==false) {
wertus.setFormValue("")
if (myValues.contains('5000')==false){
     wertcn.setFormValue("")
