Scriptrunner behaviour, issue type restriction not working when user has other language than default
Manuel Jesús Morión Barea October 3, 2019 edited
In order to restrict issue types on several projects, we have applied the sample code from https://scriptrunner.adaptavist.com/latest/jira/recipes/behaviours/restricting-issue-types.html
The code is next:
import static com.atlassian.jira.issue.IssueFieldConstants.ISSUE_TYPE
def project = issueContext.projectObject
def projectIssueTypes = project.getIssueTypes()
def issueTypeField = getFieldById(ISSUE_TYPE)
def availableIssueTypes = []
def types_list = ["Bug", "Task", "Epic", "Story", "Story Bug", "Test"]
availableIssueTypes.addAll(projectIssueTypes.findAll { (it.name in types_list) })
availableIssueTypes.each { log.error ">>>>>>>"+it.name+" => "+it.id }
issueTypeField.setFieldOptions(availableIssueTypes)
It seems to be working, except for users with profile language other than instance default.
For those users, we see the "availableIssueTypes" array has the right info, but something at UI level makes that only "Test" issue type is available in the dropdown menu.
Has anybody an idea about a solution for this?
Regards.
Tessa Tuteleers
Hey Manuel,
I just tested your script on jira 7.13 and it seems to work, if I change my profile language I get a list of issue types from the behaviour with the translated values.
Perhaps you could try working with the ID's instead?
Manuel Jesús Morión Barea October 7, 2019
Hi Tessa,
You'right, I've tested in a fresh installation of 7.9.2 (same versión as the one failing) and it's working ok.
It seems like any kind of corruption on the issue types.
This momment I'm checking the database tables.
Regards.
Patrick Gießler April 14, 2020
Hi Manuel,
I have the same problem.
Have you found a solution?
Regards
Patrick
Hi Patrick,
I received an email about this issue fixed in the last release of Scriptrunner.
I haven't tried yet.
Regards.
Patrick Gießler July 2, 2020
Yes, now it works
Tobias Banzhaf
September 23, 2020
Like • Maxime CORNET likes this
