I have installed IntelliJ IDEA and scriptrunner plugin as the following url.
https://scriptrunner.adaptavist.com/latest/jira/intellij-integration.html#_installation
But when I click the IntelliJ icon the web alert error below
And the log of InteliiJ says
ERROR - org.jetbrains.io.BuiltInServer - avax.net.ssl.SSLHandshakeException: Received fatal alert: certificate_unknown
does any one know how to use InreliiJ for delveloping scriptrunner script
or any other IDE recommend?
Scriptrunner version: 5.6.8.1-jira8
IntelliJ version: 2019.3.3
Adaptavist ScriptRunner Power Editor version: 0.7.20
Hi @Vincent Lee ,
I believe you are facing the issue reported in below bug that has been fixed in version 5.6.13:
Please update to version 5.6.13 and confirm this solves the issue. Also, notice that the IntelliJ plugin is now officially deprecated:
5.6.13
IntelliJ IDEA Plugin Deprecation
We are officially deprecating the IntelliJ IDEA plugin, also known as the Adaptavist Power Editor. ScriptRunner 5.6.13 contains the last bugfix we will ship for this feature, and 0.7.20 is the last release we will make on the JetBrains marketplace. Future support requests for this feature will be referred to this deprecation notice.[...]
You may want to review the above link for details.
Dario
Hi Dario,
Thanks for response! After I update scriptrunner to version 5.6.15, the problem solved.
But I meet new problem.
After click the IntelliJ icon, the code can import to IntelliJ succees, but I get new error as below.
Hi @Vincent Lee ,
As written on the top of the error message you are getting, please report the problem to the vendor by using the link you can find in the support tab of the marketplace page for the add-on:
However, please keep in mind that they might not fix this since, as already mentioned, the IntelliJ plugin is now officially deprecated:
Dario
If you have problems installing it into the new IntelliJ IDEA 2020.1, please see my comment here for a quick fix:
Help us plant more trees
