I am getting this error when copying a large project. The project is created but doesn't have all the issues copied from the original project
The UI might time out, but the copy operation should complete in the end. If there are any errors, they will be in your log file, so can you check that?
Hi Jamie.
I am having the exact issue that your describe.
The copyproject completes and all tlhe 188 issues are created with all the issue links, etc...
1) Is there a way to increase the UI timeout?
2) Also there are many repeated errors (possibly one for each issue - didn't count them all):
2018-05-13 00:41:50,901 http-nio-8080-exec-20 ERROR (username) 41x2208x1 d7xn9w (pi address) /rest/scriptrunner/latest/canned/com.onresolve.scriptrunner.canned.jira.admin.CopyProject [c.bit.utils.LogUtils] AtmosphereSupport:::broadcast:::skip broadcast
Thanks very much
