Scriptrunner fragment in search results
Thomas Heidenreich
March 6, 2018
Hi all,
I was thinking about triggering functions from search results. Is there a way to add a button (as fragment) to the search results which, for example, would trigger an event on all issues in the result?
thanks
Thomas
Tarun Sapra
Currently the easiest way to do it is to save the search as a filter and then in the "Built-in scripts" section of the script runner plugin there is a functionality called "Generate Events".
In this "Generate events" you can mention the event you want to generate and the filter ID.
Thomas Heidenreich
March 6, 2018
That´s a nice way to go for a Jira admin.
Unfortunately we need this to be triggered by users, or project leads.
Like • FerasOd likes this
FerasOd
September 6, 2021
Did you find a way to do that ?
