Scriptrunner link issues based on summary
Qi Jiang
May 7, 2018 edited
I have few projects: A1,B1,C1,D1 and  A2,B2,C2,D2. Inside these projects, there are some issues got same summary, I am looking for a way to link them together.
For example:
inside A1 there is a issue, A1issue1 summary is "UI submit button is not working", and in A2 there is another issue, A2issue1 summary is "UI submit button is not working" too. So I want to link A1 to A2.
Joshua Yamdogo @ Adaptavist
May 8, 2018 edited
Do you know the exact wording of the summaries that are duplicated? For example, you could write a script in the Script Console that does this:
//JQL search for issues where summary contains specific wording
//loop through all returned issues and link them together
//reindex issues
This would only work if you knew what the wording of the duplicated summaries were.
Josh
Praveen
This will be hard, since JQL doesn't compare 2 exact strings. You have to find a better way to fetch issues.
Praveen
If you search for issues with the summary as "UI submit button is not working" it might return other issues along with the required issue.
