Scriptrunner listener Updating Multi Issue Picker API
AbrahamA
April 24, 2022
Hi All
I have a multi issue picker custom field.
I need to add a new value to the custom field from my listener. I can manually add value, however I am not able to add programmatically from my listener.
def issueService = ComponentAccessor.issueService
def issueInputParameters = issueService.newIssueInputParameters()
//String valueToUpdate = issue_res.getKey()   // tried this also
String valueToUpdate = issue_res.getKey()+" "+myValue
issueInputParameters.addCustomFieldValue(productsField, valueToUpdate)
But the field is not getting updated.
I see this error:
2022-04-24 11:42:15,385 ERROR [runner.AbstractScriptListener]: Script function failed on event: com.atlassian.jira.event.issue.IssueEvent, file: null groovy.lang.MissingMethodException: No signature of method: com.atlassian.jira.issue.IssueInputParametersImpl.addCustomFieldValue() is applicable for argument types: (com.onresolve.scriptrunner.runner.field.IssueParametersCapturingImmutableCustomFieldWithDefaultValueOperations...) values: [Products, SREG-31383 PowerEdge Platform] Possible solutions: addCustomFieldValue(java.lang.Long, [Ljava.lang.String;), addCustomFieldValue(java.lang.String, [Ljava.lang.String;), getCustomFieldValue(java.lang.String), getCustomFieldValue(java.lang.Long) at Script1077$_run_closure1.doCall(Script1077.groovy:72) at Script1077.run(Script1077.groovy:65)
Any help is appreciated.
Abe
Graham Twine _Slm_
April 25, 2022 edited
Try using the fields ID
issueInputParameters.addCustomFieldValue(productsField.id, valueToUpdate)
From the documentation.
addCustomFieldValue(Long customFieldId, String... values)
Your first argument must be the fields ID and the second argument/s are string/s.
If you look at the fields ID it may be something like customfield_1234 use the 1234 in this method.
Let's build A Rovo Agent 🤖
Save your spot
