×I hope this is an easy one - I am testing out my script ( I know I will have to add an event issue when I finalize my script I am just testing with one issue for now)
import com.atlassian.jira.issue.IssueManager
import com.atlassian.jira.event.issue.IssueEventBundle
import com.atlassian.jira.event.AbstractEvent
import com.atlassian.jira.security.roles.ProjectRoleManager
IssueManager im = ComponentAccessor.getIssueManager()
MutableIssue issue = im.getIssueObject("MH-5548")
def watcherManager = ComponentAccessor.getWatcherManager()
def userUtil = ComponentAccessor.userUtil
def cField = customFieldManager.getCustomFieldObject("customfield_10625")
def system = cField.getValue(issue)
if(system == "Looker (BI)") {
userUtil.getAllUsersInGroupNames(['BI']).each { user ->
watcherManager.startWatching(user, issue)
} else {
return "hello"
For some reason when I test the value I get null. When I return system I get [Looker (BI)] which I'm assuming it is returning a value within a list.
I'm not sure what I am doing wrong here.
I think it's going wrong in this block:
The first line there is fine, but what ends up in "system" is probably not what you think iti is. The type of field determines what object you get back from that line, and because Groovy is weakly typed, it's not complaining when you get something you are not expecting.
For example, ff the field is a multi-select, then you're going to get a list of options back, if it's a single-select, then either an option or a singleton list with one option in it. You'll only get "Looker (BI)" from it as a string if the field is text, and even then, it's not a good idea to compare strings with ==, you should use string1.equals(string2)
So, back to the start. What type of field is the custom field you are reading?
This works in my instance with a Select List (Single Choice) field.
import com.atlassian.jira.security.groups.GroupManager
GroupManager gm = ComponentAccessor.getGroupManager()
MutableIssue issue = im.getIssueObject("TEST-1234")
def cField = customFieldManager.getCustomFieldObject("customfield_13126")
log.warn(system)
if(system.toString() == "High") {
gm.getUsersInGroup('jira-administrators').each { user ->
} else {
return "hello"
This should work then. Use log.info(system) to get the value before the block to confirm. In my case, it's [Entity One]
def cField = customFieldManager.getCustomFieldObject("customfield_55522")
log.warn(system)
if(system.toString().equals("[Entity One]")) {
} else {
return "hello"
Try this and let me know.
if(system.toString() == "[Looker (BI)]") {
gm.getUsersInGroup('BI').each { user ->
} else {
return "hello"
Still doesn't work. I've tried using toString() in different places and it never worked. @Mike Schultz
@Jacob Francois If you add a logging statement within the if block, does it trigger?
if so, you may need to apply the changes to the issue. With something like:
import com.atlassian.jira.issue.UpdateIssueRequest
def AuthContext=ComponentAccessor.getJiraAuthenticationContext()
updateIssueRequest = UpdateIssueRequest.builder().eventDispatchOption(EventDispatchOption.DO_NOT_DISPATCH).sendMail(false).build()
issueManager.updateIssue(AuthContext.getLoggedInUser(),
mutableIssue,
updateIssueRequest)
@Mike Schultz when I run the code I get a null return(or hello). I don't think the issue is with what is inside the if or else statement. the problem is that system == "looker (bi) goes to else when I know it is true.
Ok, as I mentioned, a single-select list won't hold a string, they hold an option.
To compare an option with a string, you probably want the name of the option, not the whole option object.
