Scriptrunner - reindex an issue
Stefan Caloian May 23, 2018
I have a report, where issues are displayed in a column. These issues have checkboxes next to them. When the checkboxes are selected and a transition is clicked, then the selected issues are supposed to transition. When the transition is clicked, a jql is performed, and all issues with checkboxes are searched. However, I think since it is not being re-indexed, the issues cannot be found. How do I re-index the issues so they can be found?
4 votes
Gaston Valente
May 23, 2018
Stefan,
Here's a groovy snippet to reindex an issue.
However, issue indexing is automatic after an update, check if you're doing the actions in the right order
Let me know if i can help you with anything else
 import com.atlassian.jira.event.issue.AbstractIssueEventListener;
import com.atlassian.jira.event.issue.IssueEvent;
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.util.ImportUtils;
import com.atlassian.jira.issue.Issue;
import com.atlassian.jira.issue.MutableIssue;
import com.atlassian.jira.issue.index.IssueIndexingService;
MutableIssue mutableIssue = ComponentAccessor.getIssueManager().getIssueObject(issue.getKey());
boolean isIndex = ImportUtils.isIndexIssues();
ImportUtils.setIndexIssues(true);
IssueIndexingService IssueIndexingService = (IssueIndexingService) ComponentAccessor.getComponent(IssueIndexingService.class);
IssueIndexingService.reIndex(mutableIssue);
ImportUtils.setIndexIssues(isIndex);
Would I place this in the script for the post function?
Gaston Valente
May 24, 2018
Stefan,
You can place it in a post function or in a listener.
Usually the last post function performs a reindex
nallu November 1, 2018
Hi @Gaston Valente,
I have created a Script listener by referring your code. But It doesn't work. Can you please look into my code and tell me what i am doing wrong.
//import com.atlassian.jira.issue.MutableIssue;
import com.atlassian.jira.issue.search.SearchProvider;
import com.atlassian.jira.jql.parser.JqlQueryParser;
import com.atlassian.jira.web.bean.PagerFilter;
Issue issue = event.issue
//Get issue key
def currKey = issue.getKey();
//Query for all features where linked epic = current key
def jqlQueryParser = ComponentAccessor.getComponent(JqlQueryParser);
def searchProvider = ComponentAccessor.getComponent(SearchProvider);
def issueManager = ComponentAccessor.getIssueManager();
def user = ComponentAccessor.getJiraAuthenticationContext().getUser();
def queryString = 'issuetype = Feature AND "Linked Epics" = ' + currKey;
def query = jqlQueryParser.parseQuery(queryString);
def results = searchProvider.search(query, user, PagerFilter.getUnlimitedFilter());
if (results)
results.getIssues().each {documentIssue ->
IssueIndexingService.reIndex(documentIssue);
Like • Willy Wijaya likes this
nallu November 7, 2018
Never mind. I fixed it. thanks!
Elsa Bautista
March 6, 2019
Nallu, how do you solved it?
Sylvain Leduc
Hello @nallu
I'm also interested :-)
What was missing ?
Willy Wijaya
Hi @nallu  and @Gaston Valente ,
Thanks a lot for the references.
Best Regards,
Willy Wijaya
Help us plant more trees
