Scriptrunner script for linking tasks based on the common value of customfield.
uvo3 main public name
jira server script runner
how to find and link current issue by common value of customfields automatically
Exmample: New and Old ticket in the project have common value of customfield. How to find Old ticket from New ticket and linked those, and update a couple fields in New ticket from Old automatically.
Is it achievable by script runner. Please help with a script
2 accepted
3 votes
Evgenii
July 7, 2023 edited
Hi, @uvo3 main public name
It can be made with scriptrunner, but maybe it's better to make with Jira Automation?
You won't need to write scripts, it can be done much easier.
July 7, 2023 edited
The automation should be applied in Jira Server 8 environment.
I'm afraid it not possible to add automation.
Could you provide guidelines how to implement that?
or if it possible to provide same script example
The script was find in community as example doesn't work for me.
import com.atlassian.jira.issue.search.SearchProvider
import com.atlassian.jira.jql.parser.JqlQueryParser
import com.atlassian.jira.web.bean.PagerFilter
import com.atlassian.jira.issue.link.IssueLinkManager
import com.atlassian.jira.user. ApplicationUser
def issueManager = ComponentAccessor.getIssueManager()
def currentIssue = issueManager.getIssueObject("TEST-11")
//def currentIssue = event.getIssue()
def linkManager = ComponentAccessor.getIssueLinkManager()
def cfm = ComponentAccessor.getCustomFieldManager()
def jqlParser = ComponentAccessor.getComponent(JqlQueryParser)
def searchProvider = ComponentAccessor.getComponent(SearchProvider)
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser() as ApplicationUser
def queryIssue
def ipVal = currentIssue.getCustomFieldValue(cfm.getCustomFieldObjectByName("Domino Aplicativo"))
def jql = jqlParser.parseQuery("${ipVal}
def results = searchProvider.search(jql, user, PagerFilter.getUnlimitedFilter())
results.getIssues().each {documentIssue ->
queryIssue = issueManager.getIssueObject(documentIssue.id)
if(queryIssue != null) {
linkManager.createIssueLink(currentIssue.Id, queryIssue.Id, 10309, 1, user )
Evgenii
No, no automation for server.
Ok, then let it be script. I will send it later
Thank in advance.
The script was detected in community as example doesn't work for me and it not complete all needs:
def queryIssue
def ipVal = currentIssue.getCustomFieldValue(cfm.getCustomFieldObjectByName("Coomon field"))
Evgenii
I think, something like this, added to postfunction, will work
* Created 2023.
* @author Evgeniy Isaenkov
* @github https://github.com/Udjin79/SRUtils
import com.atlassian.jira.bc.issue.search.SearchService
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.issue.search.SearchResults
import com.atlassian.query.Query
JqlQueryParser jqlQueryParser = ComponentAccessor.getComponent(JqlQueryParser) as JqlQueryParser
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager()
SearchService searchService = ComponentAccessor.getComponent(SearchService)
Issue issue = issue as Issue
// Set custom field name, you're looking
String fieldName = "Common Field"
CustomField cf = customFieldManager.getCustomFieldObject(fieldName)
def cfValue = issue.getCustomFieldValue(cf)
// Set link sequence and link type ID
Long sequence = 1L
Long linkType = 10000L
ApplicationUser user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
// This JQL will look for issues with similar custom fields
String jql = "project = '${issue.getProjectObject().name}' AND key != ${issue.key} AND '${fieldName}' = '${cfValue}'"
Query query = jqlQueryParser.parseQuery(jql)
SearchResults search = searchService.search(user, query, PagerFilter.getUnlimitedFilter())
List<Issue> foundIssues = search.results
foundIssues.each { Issue foundIssue ->
ComponentAccessor.issueLinkManager.createIssueLink(issue.id, foundIssue.id, linkType, sequence, user)
My pleasure Evgeniy!
Big thanks for my problem solving.
The script works great.
One more thing : As part of assignments How does update a couple fields in New ticket from Old automatically.
For example: Update custom TEXT field in New ticket called INFO with value from Old ticket TEXT field called the same INFO
Could you please to share same example too
Evgenii
Yes, sure
* Created 2023.
import com.atlassian.jira.issue.IssueManager
import com.atlassian.jira.issue.index.IssueIndexingService
IssueManager issueManager = ComponentAccessor.getIssueManager()
IssueIndexingService issueIndexingService = ComponentAccessor.getComponent(IssueIndexingService)
MutableIssue issue = issue as MutableIssue
CustomField cf = customFieldManager.getCustomFieldObject("Common Field")
CustomField cfToCopy1 = customFieldManager.getCustomFieldObject("Common Field 1")
CustomField cfToCopy2 = customFieldManager.getCustomFieldObject("Common Field 2")
Long sequence = 1L
if (foundIssues) {
Issue foundIssue = foundIssues.first()
def cfToCopy1Value = foundIssue.getCustomFieldValue(cfToCopy1)
def cfToCopy2Value = foundIssue.getCustomFieldValue(cfToCopy2)
issue.setCustomFieldValue(cfToCopy1, cfToCopy1Value)
issue.setCustomFieldValue(cfToCopy2, cfToCopy2Value)
issueManager.updateIssue(user, issue, EventDispatchOption.DO_NOT_DISPATCH, false)
issueIndexingService.reIndex(issue)
Hi, Evgeniy
awesome.
The script works accurately.
Many thanks for you support.
Like • Evgenii likes this
July 7, 2023 edited
duplicated comment
SERVER
VERSION
8
