Scriptrunner - using a Validator script to block cloning of tickets for specific workflow
Adam Gaudry
Hi there
Is there any script that I can use to block the cloning of issues? I have noticed some people are cloning closed tickets, which is recreating them with values in fields that are supposed to have values (or even appear) at the first stage of the workflow.
So far I have an easy workaround for this; put a validator in that only allows cloning if the values of the fields from later on in the workflow are blank. Doing this will stop them from cloning closed or progressed tickets, but I just wondered if there was a neater way of doing this with a script?
Best wishes
Ivan Tovbin
February 20, 2018
I suppose you can do it by taking away the permission to clone an issue when it's in a 'Closed' status. Check out this documentation for more details.
Adam Gaudry
Thanks Ivan. In the end I got round this by setting down conditions on the transitions, so cloning can't be done beyond a specific stage. This ensures that no-one can clone the tickets once they have started moving to later statuses.
