Scriptrunner: using multiple issueFunction clauses in the same JQL query
Aquarius
December 9, 2024 edited
Dear Experts,
I am using the query  that works fine and Returns Result.
project = AAA AND type = Epic AND component in (XXX)
AND issueFunction in dateCompare("", "Target end > duedate")
But as soon as I change it to:
filter= YYY
,where YYY = issueFunction in portfolioChildrenOf("filter = 'ZZZ'")
it works fine but returns No Result
Can you tell me what is wrong and which workarounds are possible?
Trudy Claspill
Hello @Aquarius
If you execute just:
filter=YYY
...do you get results?
And, if so, have you confirmed that within those results there are issues that meet the criteria of ...?
Aquarius
Yes, sure @Trudy Claspill
Trudy Claspill
Does that mean you did test the YYY filter by itself, and you did confirm it has results that meet the criteria of the dateCompare function?
Aquarius
Yes of course, @Trudy Claspill
Trudy Claspill
What is the JQL of your filter ZZZ?
I recreated the structure of your filters, and I did not encounter the same problem, but that could be because my filter TrudyTestFilterZ is not comparable to your filter ZZZ.
issueFunction in dateCompare("", "Target start >= Target end")
I found two issues with this filter where the issues are Epics that are children of a higher level issue - ABC-123
TrudyTestFilterZ:
key=ABC-123
TrudyTestFilterY:
issuefunction in portfolioChildrenOf("filter='TrudyTestFilterZ'")
Final filter:
filter='TrudyTestFilterY' and issueFunction in dateCompare("", "Target start >= Target end")
The final filter returned 2 issues
I am working with Jira DC 9.12.12 and Scriptrunner 8.35.0.
