Scriptrunner workflow Archive post function
AisM
I want to automatically archive issues that has been moved to the "Cancelled" status.
I tried using the Scriptrunner "Archive this issue" postfunction, I used the below condition- & added it as the last step of the post function after "Fire a generic event that can be processed by listeners"
issue.resolution.name == 'Cancelled'
But the issue still isn't getting archived when moved to Cancelled & the script is showing as run successfully. Can I please get some help on what I'm missing ?
Aron Gombas _Midori_
In your description, you write that you want to test the "Cancelled" status, but in that one-liner code you are testing the "Cancelled" resolution! Status and resolution are not the same!
If you really want to work with the status, then the code should be:
issue.status.name == 'Cancelled'
AisM
@Aron Gombas _Midori_  Thank you for the comment. !!
I changed the code as mentioned and still nothing. After I transition the issue to CANCELLED, nothing happens. But the logs of the script says "success".
Any idea what I'm missing
Register today
