×Hi Team,
I have written a scriptrunner code in Jira. But unfortunately the code is not synced between two nodes in jira. What would be the reason for this issue ? How to fix
The issue likely from using file-based scripts that are local to a single node, preventing them from syncing properly.
Consider implementing a shared file system and configuring it as a Script Root in ScriptRunner, ensuring seamless synchronization across nodes.
To learn more - Solved: Location of Scriptrunner scripts on Jira Data Cent...
Hope this helps - Happy to help further!!
Thank you very much and have a great one!
Warm regards
