×We have a lot of custom fields for a certain group of projects. Is there an easy way to find all custom fields for a project? JIRA 5.2.4.1
We have over 2000 custom fields and if there is a way to get all custom fields in a project that would help.
We dont want to go through every custom field and see projects. We want to look directly at a project and list the custome fields. Administration > Custom fields will not work since we have to search the project and F3 check which field it is which is the reverse. This won't help since it is in Global List it won't show
The relationship between projects and custom fields is very complex because it varies by issue type, not just project, and there's three ways to involve a custom field in a project.
To extract "what field is where", you're going to have to replicate ALL of the logic that goes into it.
So, I'm afraid the answer is "no".
