The screenshot below is from Jira in Chrome and another from Jira in Edge. Why is the search panel missing from chrome? Also, the Export link does not work in Chrome , but works in Edge,.
I'm running Chrome v102.0.5005.115.I deleted all cache & cookies in chrome for the jira site I use, but I still don't get the search panel or working Export link. Any idea on what to check?
Hi Everyone 👋
After further investigation, we have found that this issue is related to a recent Chrome experiment that was behind a feature flag. The spec for the experiment has since been changed in a way that no longer conflicts with Jira.
In order to use Issue Navigator, you will need to either...
Same issue: https://community.atlassian.com/t5/Jira-questions/Advanced-issue-search-is-missing-the-filters/qaq-p/2109166
I had it on my MacBook running Chrome 104. It didn't occur on another browser, it didn't occur on the same Chrome version on another Macbook.
Developer tools showed the following error:
Uncaught TypeError: Cannot set properties of null (setting '_validateClickToClose')
at Object._initShareDialog (batch.js?agile_global_admin_condition=true&feature-enable-ip-allowlisting-alerts=true&jag=true&jaguser=true&locale=en-US&sd_operational=true:2904:56)
at d (batch.js?locale=en-US:formatted:1819:26)
at Object.fireWith (batch.js?locale=en-US:formatted:1873:76)
at Function.ready (batch.js?locale=en-US:formatted:1541:23)
at HTMLDocument.a (batch.js?locale=en-US:formatted:1792:15)
Indeed, debugging the code showed that the popup object is null.
Update: I fixed it by deleting Chrome and reinstalling Chrome as well as deleting all data from:
~/Library/Application Support/Google
I get the same thing with the same Chrome version. When I do the above, I get the following in my console log:
DevTools failed to load source map: Could not load content for https://jira.domain.com/s/766a811df255f424194ac70ee4b0aac2-T/-idms1r/820005/1tpundx/9949f9f5a8af0454eb301d465b8cf0ef/_/download/contextbatch/js/jira.view.issue,viewissue.standalone,jira.navigator.kickass,atl.general,jira.global,jira.navigator,jira.general,jira.navigator.simple,jira.navigator.advanced,-_super/column-module.8ef50e6cb5d90eb66cd2.js.map: HTTP error: status code 503, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load source map: Could not load content for https://jira.domain.com/s/651cd52efa63cf40ddcb9055720bbbff-CDN/-idms1r/820005/1tpundx/d56b4038e5e4a49ad88e9143cd93fd84/_/download/contextbatch/js/com.atlassian.jira.plugins.jira-development-integration-plugin:7,jira.rich.editor.api,jira.rich.editor,-_super,-jira.view.issue,-jira.navigator.kickass,-atl.general,-viewissue.standalone,-jira.global,-jira.navigator/7.1177d165aa98a228b4db.js.map: HTTP error: status code 503, net::ERR_HTTP_RESPONSE_CODE_FAILURE
DevTools failed to load source map: Could not load content for https://jira.domain.com/s/36f1ab26b7d7654432e0730c16761082-CDN/-idms1r/820005/1tpundx/afa3d4c4b9a63d87d01a0af4ba734346/_/download/contextbatch/js/com.atlassian.jira.plugins.jira-development-integration-plugin:0,-_super,-com.atlassian.jira.plugins.jira-development-integration-plugin:7,-jira.view.issue,-jira.global,-jira.navigator.kickass,-atl.general,-jira.rich.editor,-viewissue.standalone,-jira.rich.editor.api/0.075180f0a8e207fec1f8.js.map: HTTP error: status code 503, net::ERR_HTTP_RESPONSE_CODE_FAILURE
batch.js?locale=en-GB:295 JQMIGRATE: Migrate is installed, version 1.4.1
batch.js?locale=en-GB:1199 Use of `window.Backbone` through AUI is deprecated and will be removed in AUI 10.0.0
hqGD @ batch.js?locale=en-GB:1199
i @ batch.js?locale=en-GB:445
r @ batch.js?locale=en-GB:445
t @ batch.js?locale=en-GB:445
(anonymous) @ batch.js?locale=en-GB:1199
batch.js?locale=en-GB:1367 Use of `window._` through AUI is deprecated and will be removed in AUI 10.0.0
snLL @ batch.js?locale=en-GB:1367
(anonymous) @ batch.js?locale=en-GB:1367
batch.js?locale=en-GB:368 Downloading resources:
batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:147137 Download the React DevTools for a better development experience: https://fb.me/react-devtools
batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:84245 @atlaskit/layer has been deprecated. It is an internal component and should not be used directly.
(anonymous) @ batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:84245
./node_modules/@atlaskit/layer/dist/esm/components/Layer.js @ batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:84553
__webpack_require__ @ batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:72170
./node_modules/@atlaskit/layer/dist/esm/index.js @ batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:84678
(anonymous) @ batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:77625
./node_modules/@atlaskit/droplist/dist/esm/components/Droplist.js @ batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:77858
./node_modules/@atlaskit/droplist/dist/esm/index.js @ batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:78384
(anonymous) @ batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:73903
./node_modules/@atlaskit/dropdown-menu/dist/esm/components/DropdownMenuStateless.js @ batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:74241
./node_modules/@atlaskit/dropdown-menu/dist/esm/components/DropdownMenu.js @ batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:73779
./node_modules/@atlaskit/dropdown-menu/dist/esm/index.js @ batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:74942
./src/main/frontend/src/WorkFlows.js @ batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:168080
./src/main/frontend/src/webpanel.js @ batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:168449
./src/main/frontend/src/index.js @ batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:168428
(anonymous) @ batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:72238
(anonymous) @ batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:72241
batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:77656 @atlaskit/droplist has been deprecated. It is an internal component and should not be used directly.
(anonymous) @ batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:77656
js!/s/d41d8cd98f00b204e9800998ecf8427e-CDN/-idms1r/820005/1tpundx/d06015502644e17e5a3997626f26e323/_/download/contextbatch/js/browser-metrics-plugin.contrib,-_super,-jira.view.issue,-jira.navigator.kickass,-viewissue.standalone,-atl.general/batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&richediton=true&threaded-comments=true!order
batch.js?locale=en-GB:515 DEPRECATED JS - AJS.debounce has been deprecated since 8.0.0 and will be removed in 10.0.0. Use equivalent functions from libraries like lodash / underscore instead
at m.init (https://jira.domain.com/s/1512dfd28b2b329ca4d006de62913fcd-CDN/-idms1r/820005/1tpundx/d2ea1e882b4acc8e627b108a99724f6d/_/download/contextbatch/js/_super/batch.js?locale=en-GB:780:2077)
i @ batch.js?locale=en-GB:515
(anonymous) @ batch.js?locale=en-GB:515
init @ batch.js?locale=en-GB:780
v @ batch.js?locale=en-GB:780
created @ batch.js?locale=en-GB:780
x @ batch.js?locale=en-GB:495
S @ batch.js?locale=en-GB:495
P @ batch.js?locale=en-GB:495
f @ batch.js?locale=en-GB:495
batch.js?locale=en-GB:515 DEPRECATED JS - Inline dialog constructor has been deprecated and will be removed in a future release. Use inline dialog 2 instead.
at https://jira.domain.com/s/766a811df255f424194ac70ee4b0aac2-T/-idms1r/820005/1tpundx/9949f9f5a8af0454eb301d465b8cf0ef/_/download/contextbatch/js/jira.view.issue,viewissue.standalone,jira.navigator.kickass,atl.general,jira.global,jira.navigator,jira.general,jira.navigator.simple,jira.navigator.advanced,-_super/batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:1510:335
(anonymous) @ batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:1510
l @ batch.js?locale=en-GB:10
u @ batch.js?locale=en-GB:10
(anonymous) @ batch.js?locale=en-GB:10
setTimeout (async)
s @ batch.js?locale=en-GB:10
window.require @ batch.js?locale=en-GB:15
(anonymous) @ batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:1632
batch.js?locale=en-GB:795 Found a 'popup' attribute with an invalid value.
500batch.js?locale=en-GB:515 DEPRECATED undefined - AJS.params has been deprecated since 9.0.0 and will be removed in 10.0.0.
at r.init (https://jira.domain.com/s/1512dfd28b2b329ca4d006de62913fcd-CDN/-idms1r/820005/1tpundx/d2ea1e882b4acc8e627b108a99724f6d/_/download/contextbatch/js/_super/batch.js?locale=en-GB:1412:951)
get @ batch.js?locale=en-GB:665
init @ batch.js?locale=en-GB:1412
(anonymous) @ batch.js?locale=en-GB:1047
r @ batch.js?locale=en-GB:1047
init @ batch.js?locale=en-GB:1417
init @ batch.js?locale=en-GB:1501
attached @ batch.js?locale=en-GB:4535
c @ batch.js?locale=en-GB:906
r @ batch.js?locale=en-GB:901
batch.js?locale=en-GB:515 DEPRECATED JS - PopulateParameters has been deprecated since 9.0.0 and will be removed in 10.0.0.
at HTMLDocument.<anonymous> (https://jira.domain.com/s/1512dfd28b2b329ca4d006de62913fcd-CDN/-idms1r/820005/1tpundx/d2ea1e882b4acc8e627b108a99724f6d/_/download/contextbatch/js/_super/batch.js?locale=en-GB:665:1307)
(anonymous) @ batch.js?locale=en-GB:665
i @ batch.js?locale=en-GB:54
fireWith @ batch.js?locale=en-GB:54
ready @ batch.js?locale=en-GB:54
H @ batch.js?locale=en-GB:54
batch.js?locale=en-GB:1649 To be compatible with jQuery 1.9 and higher, You must pass a selector to tipsy's live argument. For instance, `$(document).tipsy({live: 'a.live'});`
t.fn.tipsy @ batch.js?locale=en-GB:1649
(anonymous) @ batch.js?locale=en-GB:1659
c @ batch.js?locale=en-GB:1659
XphB.i.default.fn.tooltip @ batch.js?locale=en-GB:1659
(anonymous) @ batch.js?locale=en-GB:1735
at v (https://jira.domain.com/s/1512dfd28b2b329ca4d006de62913fcd-CDN/-idms1r/820005/1tpundx/d2ea1e882b4acc8e627b108a99724f6d/_/download/contextbatch/js/_super/batch.js?locale=en-GB:4490:5450)
v @ batch.js?locale=en-GB:4490
(anonymous) @ batch.js?locale=en-GB:4490
batch.js?locale=en-GB:4637 Cannot bind new shortcut "pc" due to conflict with existing shortcut "p"
batch.js?locale=en-GB:4637 Cannot bind new shortcut "p?" due to conflict with existing shortcut "p"
batch.js?locale=en-GB:4637 Cannot bind new shortcut "pt" due to conflict with existing shortcut "p"
batch.js?locale=en-GB:4637 Cannot bind new shortcut "ps" due to conflict with existing shortcut "p"
batch.js?locale=en-GB:4637 Cannot bind new shortcut "pr" due to conflict with existing shortcut "p"
batch.js?locale=en-GB:4637 Cannot bind new shortcut "pR" due to conflict with existing shortcut "p"
batch.js?locale=en-GB:4637 Cannot bind new shortcut "pS" due to conflict with existing shortcut "p"
batch.js?locale=en-GB:4637 Cannot bind new shortcut "pf" due to conflict with existing shortcut "p"
batch.js?locale=en-GB:4637 Cannot bind new shortcut "pn" due to conflict with existing shortcut "p"
batch.js?locale=en-GB:4637 Cannot bind new shortcut "pv" due to conflict with existing shortcut "p"
at Object._initShareDialog (https://jira.domain.com/s/766a811df255f424194ac70ee4b0aac2-T/-idms1r/820005/1tpundx/9949f9f5a8af0454eb301d465b8cf0ef/_/download/contextbatch/js/jira.view.issue,viewissue.standalone,jira.navigator.kickass,atl.general,jira.global,jira.navigator,jira.general,jira.navigator.simple,jira.navigator.advanced,-_super/batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:6093:4847)
_initShareDialog @ batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:6093
batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:6093 Uncaught TypeError: Cannot create property '_validateClickToClose' on string '[object Object]'
at Object._initShareDialog (batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:6093:4918)
at i (batch.js?locale=en-GB:54:22867)
at Object.fireWith [as resolveWith] (batch.js?locale=en-GB:54:23648)
at Function.ready (batch.js?locale=en-GB:54:25432)
at HTMLDocument.H (batch.js?locale=en-GB:54:22645)
css!/s/a345af1ed691c140abb7dd381776bce9-CDN/-idms1r/820005/1tpundx/8e9801c5a08c666bfb7a78f4efc090ed/_/download/contextbatch/css/com.atlassian.jira.plugins.jira-development-integration-plugin:7,com.atlassian.jira.plugins.jira-development-integration-plugin:0,jira.rich.editor.api,jira.rich.editor,-_super,-jira.view.issue,-jira.navigator.kickass,-atl.general,-viewissue.standalone,-jira.global,-jira.navigator/batch.css?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&richediton=true&threaded-comments=true
js!/s/7d6fbce43e01672e8f50971eb0d87e34-CDN/-idms1r/820005/1tpundx/8e9801c5a08c666bfb7a78f4efc090ed/_/download/contextbatch/js/com.atlassian.jira.plugins.jira-development-integration-plugin:7,com.atlassian.jira.plugins.jira-development-integration-plugin:0,jira.rich.editor.api,jira.rich.editor,-_super,-jira.view.issue,-jira.navigator.kickass,-atl.general,-viewissue.standalone,-jira.global,-jira.navigator/batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true!order
js!/s/d41d8cd98f00b204e9800998ecf8427e-CDN/-idms1r/820005/1tpundx/4.7.2/_/download/resources/com.atlassian.jira.plugins.jira-editor-plugin:tinymce/tinymce.js?batch=false!order
js!/s/d41d8cd98f00b204e9800998ecf8427e-CDN/-idms1r/820005/1tpundx/4.7.2/_/download/resources/com.atlassian.jira.plugins.jira-editor-plugin:tinymce/tinymce-amd.js?batch=false!order
js!/s/d41d8cd98f00b204e9800998ecf8427e-CDN/-idms1r/820005/1tpundx/4.7.2/_/download/resources/com.atlassian.jira.plugins.jira-editor-plugin:tinymce/icons.js?batch=false!order
js!/s/d41d8cd98f00b204e9800998ecf8427e-CDN/-idms1r/820005/1tpundx/4.7.2/_/download/resources/com.atlassian.jira.plugins.jira-editor-plugin:tinymce/themes/silver/theme.js?batch=false!order
DevTools failed to load source map: Could not load content for https://jira.domain.com/s/7d6fbce43e01672e8f50971eb0d87e34-CDN/-idms1r/820005/1tpundx/8e9801c5a08c666bfb7a78f4efc090ed/_/download/contextbatch/js/com.atlassian.jira.plugins.jira-development-integration-plugin:7,com.atlassian.jira.plugins.jira-development-integration-plugin:0,jira.rich.editor.api,jira.rich.editor,-_super,-jira.view.issue,-jira.navigator.kickass,-atl.general,-viewissue.standalone,-jira.global,-jira.navigator/0.075180f0a8e207fec1f8.js.map: HTTP error: status code 503, net::ERR_HTTP_RESPONSE_CODE_FAILURE
js!/s/d58f74a9678ef551516fc7bd9b457bba-CDN/-idms1r/820005/1tpundx/aa2625670815c57dd29301a2405ef21b/_/download/contextbatch/js/com.atlassian.jira.plugins.jira-quicksearch-plugin:5,-_super,-jira.view.issue,-jira.global,-com.atlassian.jira.plugins.jira-development-integration-plugin:0/batch.js?jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true!order
at f._initDialog (https://jira.domain.com/s/766a811df255f424194ac70ee4b0aac2-T/-idms1r/820005/1tpundx/9949f9f5a8af0454eb301d465b8cf0ef/_/download/contextbatch/js/jira.view.issue,viewissue.standalone,jira.navigator.kickass,atl.general,jira.global,jira.navigator,jira.general,jira.navigator.simple,jira.navigator.advanced,-_super/batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:1007:2832)
_initDialog @ batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:1007
initialize @ batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:1007
f @ batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:1007
m @ batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:1007
n.showOnboardingTip @ batch.js?jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:5
(anonymous) @ batch.js?agile_global_admin_condition=true&baseurl-check-resources=true&healthcheck-resources=true&jag=true&jaguser=true&jira.create.linked.issue=true&locale=en-GB&richediton=true&threaded-comments=true:170000
Promise.then (async)
dispatch @ batch.js?locale=en-GB:64
v.handle @ batch.js?locale=en-GB:64
I've tried incognito, clearing cache, disabling extensions, but nothing helps.
I also can't see the left side navigation pane, it's just blank.
This started for Chrome 102, I previously ran Chrome 100 and that worked fine.
Hi @Chris Hankey ,
Welcome to the community !
Please try below steps and let me know how it goes
1. Empty browser cache and hard reload
2. Try in incognito mode
3. Disable all chrome add-ons and recheck.
I do see the error below in the chrome console. I don't see this error when I load the same page in Edge.
Hi All,
1. Please check Chrome and see if there are any available updates. Re-install Chrome completely if an update doesn't resolve it.
2. Restart your laptop and check if it resolves the issue.
3. Enable safe mode in jira and recheck. If issue is solved, then it could be one of the plugins causing the issue. You need to disable one-by-one and check which plugin is causing the issue.
If its still an issue and as other people also reported the issue, I would suggest raise a support ticket with Atlassian.
I am also using Chrome 102.0.5005.115, but all works fine. I am using Jira 8.13.15 version. What is your jira software version ?
Help us plant more trees
