Search returns wrong project issues
Del Jensen
April 4, 2019
We have several projects setup. Two of those projects have project keys of ENGHARBOR (Harbor) and CPOINT (Centerpoint). When I enter a simple search for:
project = ENGHARBOR AND resolution = Unresolved ORDER BY priority DESC, updated DESC
This will return issues in the ENGHARBOR project.
If I let Jira change the ENGHARBOR to Harbor, it will return issues in the CPOINT project.
project = Harbor AND resolution = Unresolved ORDER BY priority DESC, updated DESC
Affects Version/s
7.13.0
Antoine Berry
April 4, 2019
I would suggest either using the key without quotes, or the name of project with quotes, i.e. :
project = ENGHARBOR
project = "Harbor"
Antoine
Del Jensen
April 4, 2019
Thank you.
When I do this and press the search button
project = ENGHARBOR
It returns the expected results.
If I type and let Jira auto-change to Harbor (that's the project Name) it returns the CPOINT project issues.
project = Harbor
When I use this, it returns the CPOINT project issues.
project = "Harbor"
Other projects return correctly, at least the ones I've tried.
Antoine Berry
April 5, 2019
Well this is beyond my knowledge then. :)
Looks like a bug. I usually use the key of the project anyway because I am sure this is unique and it is shorter. I guess this is a problem for users in your case that use the name of the project instead ?
Del Jensen
April 5, 2019
Thank you for your help!  Greatly appreciated!
I prefer using the key of the project also.  Jira, when creating the search string, will auto-fill to the name even if enter the key, at least in our instance it does.  I submitted the issue to Atlassian, if I hear anything, I'll post it here.
Like Antoine Berry likes this
