Searching by approvers field in JIRA
tokuda
July 7, 2019
I use JIRA cloud. And my team uses "approvers" field to request for reviewing casually. But I seem that we can not search by "approvers" field by using JQL. Please teach me how to search by "approvers" field on JIRA.
8 votes
Zack Zhang
November 26, 2022
Go to your Issue settings > FIELD > Custom Fields.
Choose Approvers > Edit Details, Change "Search Template" from None to "User Picker & Group Searcher"
Then you can search approvers in JQL.
Jawann Swislow
This is the answer. Should be at the top. Thank you.
Like • 2 people like this
4 votes
Tansu Akdeniz
Hi @tokuda ,
Please check this one:
  • Approvals = approver("TANSU")
It finds requests that require or required approval by Tansu.
Functions:
Detailed info: https://confluence.atlassian.com/jiracorecloud/advanced-searching-fields-reference-765593716.html#Advancedsearching-fieldsreference-ApprovalsApprovals
Hope it helps.
Tansu
tokuda
July 9, 2019
Thanks for your comments.
But my team doesn't use `Jira Service Desk`, so I can't use the function `Approvals`.
I want to filter by `approvers` without `Jira Service Desk`.
Like • Samuel P likes this
Muaz Othman
February 4, 2021
Hi @Tansu Akdeniz
As @tokuda mentioned, this field is only available in "Jira Service Management" per the documentation you linked to.
Any suggestions on how to get a similar functionality in Jira Cloud?
Tansu Akdeniz
You can simply use
  • Approvers = currentUser()
OR
  • Approvers = userA
What do you want to search specifically?
Muaz Othman
February 5, 2021
Tried this simple query:
project = "LG" AND Approvers = currentUser() ORDER BY created DESC
and got this error:
Field 'Approvers' is not searchable, it is only sortable.
Like • 5 people like this
Jyoti Verma
This was Great and helped me - thanks a lot
Jeret Shuck
I'm also looking for something similar. Effectively, I need something that is
"Approvers is empty"
As others have posted, it seems like there is no way to use a JQL function on the "approvers" field on the Jira cloud currently.
Jason Sweet
Hello and sorry to hijack this question but I have the same problem.  I'm trying to filter on a specific name in the Approvers field, across multiple projects, some of which are service desk and some are classic business.
I have tried:
status = "Awaiting Approval" AND Approvals = approver("rmitchell") ORDER BY created DESC
and get No Issues found.
Any advice here?  Thank you very much in advance.
Vanessa McGonigle March 4, 2020
If the approvers field contains more than one user that jql will not identify the issue as relevant to the jql. I'm not sure what the right query is though.
Corey Needham March 16, 2020 edited
You can use the OR function to separate queries to both fields to return all of the results.
status = "Awaiting Approval" AND Approver = 5d7bd791458a170db4b0a687 OR status = "Awaiting Approval" AND Approvals = approver("Jason Sweet")
Where 5d7bd791458a170db4b0a687 is Jason Sweet's ID , it will return both Software and Servicedesk issues that Jason sweet has been or is an approver on that is currently "Awaiting Approval"
(TIP: if you type out the "Approver =  " part of the query you can search users by name and it will input the ID)
