Searching for issues with a specific label
Sandy Greenberg
I'm struggling with a JQL query that will bring back issues with a specific label, even if there are other labels on the issue.
"project in (UKSCR, COMPRG) AND issuetype = Bug AND labels in (BAT)" and
"project in (UKSCR, COMPRG) AND issuetype = Bug AND labels = BAT"
don't work because they both bring back issues with ONLY the label "BAT".  If the issue has "BAT" in addition to other labels it doesn't get returned.
It would help if there was an "includes" operator but there isn't.  Any ideas?
5 votes
Sandy Greenberg
Damn.  Never mind folks.  I forgot the number 1 rule of testing which is "don't believe what anyone tells you".  I was given a link to a specific JIRA issue and was told that it should be in my list but wasn't.  When I looked it had more than one label so I (incorrectly) assumed that that was the problem.
No, the problem is that it was a "Story" and not a "Bug".  (headslap).  Stand down.  Soz.
Grigory Salnikov
September 12, 2018
It happens all the time :)
Like • 3 people like this
Grigory Salnikov
September 12, 2018
Hi!
It's strange because here the opposite behaviour is reported:
Filter issues that have only one specific label and no other labels
Grigory Salnikov
September 12, 2018 edited
Update: I've reproduced the situation in my environment and can confirm that search by labels works as described in the article above. The JQL:
project = ADM AND labels in (test1)
returns all the issues with the label 'test1' no matter how many other labels are there.
Sandy Greenberg
It may be strange but it's true.  I get 15 issues returned with the label "BAT" but not the three issues with "BAT" and "Delphi".
Grigory Salnikov
September 12, 2018
Are you sure you don't have two different labels which look alike? For example, one letter could be written in a different language or something. Please, make sure.
Sandy Greenberg
Yeah, my bad.  See below.
Grigory Salnikov
September 12, 2018
It's above now and it's ok.
Kim Cavalier
August 23, 2022
Ineed to find issues with a specific label but must not have a specific other label
Register today
