How to make most effectively a searching syntax, which will return complete epic, its tasks and their sub-tasks? I need to save this searching as a filter to get the Timespent report, where work log is saved on epic level, tasks level and sub-tasks level. I have no problem, when tasks level-1 are in the epic only, but I can't get the full range, when there are also sub-tasks. Thanks in advance for help.
Hi Piotr,
On the assumption you are using cloud (as I am), this will return all items below an epic, including sub-tasks. Please let me know if this works or not.
project = "XXX" And "Epic Link" = XXX-123 OR parent in ("XXX-123") or parentEpic = "XXX-123" ORDER BY created DESC
Take care,
Michael
Hi Michael, thank you for a quick response.
I found out in the meantime that "parent in ()" works, however "parentEpic" looks much better to me as in the former case I have to put issue code of every single task level-1, whereas I could put one value in "parentEpic=" getting the same result (I assume I could use either "parent in ()" or parentEpic=" as an equivalent).
Unfortunately "parentEpic" doesn't work in my Jira. I am given the message "Field 'parentEpic' does not exist or you do not have permission to view it."
BR
Piotr
Are you using Data Center, Cloud, or Server? And, which version?
Michael
