Security level in my custom plugin
d-sokolovskiy December 28, 2017 edited
Hi!
  Can you tell me how to make such a change in the code in my custom plugin that only users from one particular group can use this add-on?
Alexey Matveev
December 28, 2017
Find the entry point in your plugin and put there condition on user groups.
thank you
Daniel Wester
December 30, 2017
Take a look at SALs usermanager - it’s probably got the easiest api for this. But you’ll have to do it programmatically.
Youll probably also want to ask these types of questions of at community.developers.atlassian.com
Domenico Manzo _Actonic_
December 28, 2017
You cannot add some "security level" for entire add-on. Because add-on is a set of pages, JQL functions, gadgets and so on.
You should add permission check for each module:
  • For "webworks" (pages) you can use "roles-required" attribute
  • For gadgets you should check user permission ot group programmatically
  • etc.
Register now
