Sign up Log in
Security level
Cristina Andrei
If a user  want to be able to set a particular security level in on some issues in "X" Project he has to be assigned to that particular security level?
2 accepted
Dirk Ronsmans
November 4, 2022
Correct, to set a certain level you must be part of that level.
If that's an issue you can create a more "dynamic" issue security level by setting it based on a custom field with an automation or with a group picker field.
especially the last option here is an interesting one. it allows you to pretty much create a single level and depending on a user or group picker field you can show/hide the issue
Cristina Andrei
@Dirk Ronsmans  thank you!
Like John Funk likes this
John Funk
November 4, 2022
Hi Cristina,
I would say yes, but you should test it out to be sure. First though, the user must have the ability to Set issues security in the Permission Scheme.
Cristina Andrei
@John Funk thank you
