Self-populating custom lookup field
M_S_
September 6, 2017
I would like to create a custom field with a dual nature: users should either be able to select from previously entered values or enter a new value (which in turn is then available to pick for subsequent issues).
Is there such a custom field type that supports this?
2 accepted
M_S_
September 8, 2017
Well, I guess, in that case I will be looking at nFeed (an excellent plug-in) to pull data from a database and think about keeping up a table there with values that we will be using. May actually be better in my case, as it prevents users from creating duplicate entries accidentially.
Nic Brough -Adaptavist-
September 6, 2017
No, and as far as I can tell, no one has written an add-on to provide such a field.
The closest you can get is very close - a label field.  It accepts new input values, but suggests exisiting ones when the user starts typing.
M_S_
September 6, 2017
"...suggests existing ones..." means based on the browser? This would have nothing to do with JIRA and not work across users/computers?
September 6, 2017
I don't understand that comment.
A label field makes suggestions based on pervious labels that have been entered.
