Send a web request from a SIL script
Chris Kast
Is it a all possible to send a web request (GET, POST, etc.) or even send a curl command from SIL script? Thanks!
Silviu Burcea
May 7, 2015
Yes, it is possible, we have httpGet and httpPost routines for web requests and if you need to call the curl command, we have the system routine.
Docs:
https://confluence.kepler-rominfo.com/display/SIL30/httpGet
https://confluence.kepler-rominfo.com/display/SIL30/system
anton ronin May 13, 2016
no request body access, no payload, no SOAP
not its not possible
Silviu Burcea
May 13, 2016
What are you trying to achieve, Anton? I'm sure there is a way for you, too.
anton ronin May 25, 2016
Possible with SIL system routine. Beware of problem with passing parameters with spaces.
teilor_soares
May 7, 2015
No, is not possible. I'm don't know what you want to achieve, but webhooks might be a solution for you: https://confluence.atlassian.com/display/JIRA/Managing+Webhooks
Cheers!
Teilor
Chris Kast
Basically what I want to do is, on issue create, look for string format in the description (i.e. via regex) and if it matches, send a web request that contains info from that string.
teilor_soares
May 8, 2015
I believe you could do this using ScriptRunner, but I'm not sure how. I found some examples here https://answers.atlassian.com/questions/314819/making-a-rest-call-using-script-runner
Silviu Burcea
May 8, 2015
Teilor, he's already using JJupin and JJupin can solve his problem. Personally, I won't try a new plugin that might solve a problem if I already have a solution in my own toolbox.
Learn more
