I need to be able to send people with a certain role a custom email with a customized Subject Line when an issue executes through a transition in the Workflow. I've used ScriptRunner to do this in version 6.4 of Jira, but now we have upgraded and I wondered if there's a way to do this without buying the ScriptRunner add on. We're using Jira Server version 8.17.1.
Hi @kdickason
You can try jira automation lite which may have the capabilities to send email when a transition is triggered. Link: https://marketplace.atlassian.com/apps/1211836/automation-for-jira-server-lite?tab=overview&hosting=server
Cheers.
Hi @Fabian Lim
I do not believe the free/Lite version of automation for Server supports the sending email action: https://confluence.atlassian.com/automation/getting-the-right-version-993924597.html
The paid/Pro version does have this feature.
Best regards,
