Send email to user in custom field when issue transitions
Michelle Larson
March 22, 2016
We have a workflow that has a field called Reviewer and in the workflow the assignee will click the transition Needs Reviewed, what they want is for an email to be sent to the the email address of the user listed in the Reviewer field.
Mark McCormack (Adaptavist)
March 22, 2016
Hi Michelle,
The functionality you want is documented in our built-in scripts section of the ScriptRunner documentation.
I read this again, as a transition, you need to do the following steps
  1. edit your existing workflow
  2. choose Add PostFunction
  3. Choose Script Post Function
  4. Choose Send a custom email
  5. Add "Send to reviewer" in the note field
  6. Find out the customfield_id of your Reviewer field (this link shows you how to find your customfield id)
  7. put this value into the "To issue fields" textbox Screen Shot 2016-03-22 at 20.35.12.png
  8. Choose the Add button and your publish the new workflow.
I hope that helps.
Michelle Larson
March 23, 2016
I did this and it shows in the workflow that it has successfully sent 2 email's I had me listed in the reviewer field however I never got email for it.  I think the issue is that Reviewer is the user name (selected by the user picker) and not an email address is there any way to get it to send to the users email?
Like • Rachel Uptain likes this
Sten Sundelin
March 22, 2016
Adaptavist Scriptrunner (a paid-for add-on) has a built-in script to send custom emails.
You can probably run this as a post-function in the transition.
Not sure of other ways to do this.
Tibor Hegyi _META-INF_
If for any reason ScriptRunner is not enough, you can try Email This Issue (also paid-for) that has built-in support for a full featured email postfunction which you can use to flexibly specify recipients, email templates and add attachments to the email.
