This is follow up of https://jira.atlassian.com/browse/JRASERVER-71536 which is not fixed properly
The work around provided for fixed versions isn't working. The issue still persists.
Currently following work around provided for non-fixed version and its working, Looking forward dark feature support instead of change urlrewrite.xml file.
Hm, check open Jira's right most of system still open
https://jira.ncsa.illinois.edu//secure/QueryComponent!Default.jspa
But I would say sensitive data I did not find, because the same info I can find in other vectors like google dorks and logs in different forums, code in github, bitbucket, gitee.
