I have update our JIRA core recently and the JIRA Service Desk Application cannot be installed . I can see the button install as below :
When i click install though i get "An unexpected error occurred. Refer to the logs for more information.". I have tried reinstalling jirs service desk using the linux installer . i have rebooted the server but nothing still the same thing .
Below are the logs:
2017-08-03 14:30:30,862 UpmAsynchronousTaskManager:thread-1 INFO kleanthis 1017x212x2 jpb7is 192.168.6.114 /rest/plugins/1.0/available/featured [c.a.plugin.loaders.ScanningPluginLoader] No plugins found to be installed
2017-08-03 14:30:30,907 UpmAsynchronousTaskManager:thread-1 INFO kleanthis 1017x212x2 jpb7is 192.168.6.114 /rest/plugins/1.0/available/featured [c.a.plugin.manager.DefaultPluginManager] Updating plugin 'com.atlassian.servicedesk.application' from version '3.6.2' to version '3.6.2'
2017-08-03 14:30:30,910 UpmAsynchronousTaskManager:thread-1 INFO kleanthis 1017x212x2 jpb7is 192.168.6.114 /rest/plugins/1.0/available/featured [c.a.plugin.loaders.ScanningPluginLoader] Removed plugin 'com.atlassian.servicedesk.application'
2017-08-03 14:30:33,409 UpmScheduler:thread-3 WARN kleanthis 1017x212x2 jpb7is 192.168.6.114 /rest/plugins/1.0/available/featured [c.a.upm.pac.PacClientImpl] Update check request may take longer because of the number of add-ons
Can anyone help with this?
Hi Kleanthis,
I'm sorry to hear you're running into that issue. Here is what I would do:
select * from pluginstate where pluginenabled = 'false';
UPDATE pluginstate SET pluginenabled='true' where pluginenabled = 'false';
Try those steps and let me know the outcome.
Branden
Thank you! I was having this same issue and this did indeed resolve it. I had other plugins disabled and needed to update only servicedesk and jira software.
UPDATE pluginstate SET pluginenabled='true' where pluginkey = 'com.atlassian.servicedesk.application';
UPDATE pluginstate SET pluginenabled='true' where pluginkey = 'com.atlassian.jira.jira-software-application';
Same problem here, fix worked.
But not before I've spent about 4 hours uninstalling, re-installing, rolling back, manually replacing plugins etc.
Might be worth writing this up somewhere a little more prominent?
Same problem for me with JIRA Core 7.8.2 and JIRA Service Desk 3.11.2 (I tried many combinations of plugins versions before I found this solution).
There was a plugin with name "com.atlassian.jira.plugins.workinghours" in pluginstate and pluginenabled parameter as false, after I ran db fix, it's working.
M.
tanx
i have same problem and its now solved!
Just wanted to let you know that the same problem appeared after upgrading to 8.13.2 and/or 8.14.0.
Many thanks @somethingblue for the provided solution!
I found this issue after upgrading to 7.5. and this solution did in fact resolve it. I'd like to know why this would've happened?
Same for me. It worked after upgrading to 7.5
After restarting I found Service Desk as 'installed' but needs update in Applications. after downloading it was updated and everything went well
Learn more
