Set Component in groovy script
purchasing mobileye.com December 14, 2017
I want to set a component value in a post-function of the creation of an issue.
Therefore, I created a groovy script in the post-function of the create issue that set a specific value to the issue.
If this specific value is not exists in the project component list, the script will create it first and then will set this component to the issue.
Here is my script:
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.issue.comments.CommentManager
import com.atlassian.jira.util.ImportUtils
import com.atlassian.jira.user.util.DefaultUserManager
import com.atlassian.crowd.embedded.api.User
import com.atlassian.jira.project.Project
import com.onresolve.scriptrunner.runner.util.UserMessageUtil
import org.apache.log4j.Logger
import org.apache.log4j.Category
def Category log = Category.getInstance("com.onresolve.jira.groovy.Condition")
log.setLevel(org.apache.log4j.Level.DEBUG)
MutableIssue myIssue = issue
Project project = myIssue.getProjectObject()
def theComponent = ComponentAccessor.getProjectComponentManager().findByComponentName(project.getId(),'PSW')
//log.info("The Component is: " + theComponent)
if (theComponent == null) {
theComponent = ComponentAccessor.getProjectComponentManager().create("PSW","PSW component","",0,project.getId())
//log.info("The Component not exists")
//log.info(theComponent)
myIssue.setComponent([theComponent])
Something is not working here. The component is not set to the new issue, any idea why?
5 votes
Alexey Matveev
December 14, 2017
myIssue.store()
It's still not working...
Any other idea?
Alexey Matveev
December 14, 2017
Try this script. It works for me. Do not forget that only Project Administrator can create a component if the component is absent
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser();
ComponentAccessor.getIssueManager().updateIssue(user,myIssue,EventDispatchOption.ISSUE_UPDATED,true)
Like • 4 people like this
Thank you so much!
Now it's working perfect!
Tomas Gustavsson
April 9, 2019
I used this script, with
SCRIPTRUNNER and the predefined, Clones an issue, and links listner.
It works perfect after comment out
from the script above.
Thanks you very much
Alexey Matveev [cPrime]
Alexey Matveev
December 14, 2017 edited
Is the post functin on creation? if so add issue.store()
And your post function must be before reindexing post function
Thank you.
Where should I add it? (the issue.store())
Register now
