I saw this post.
However, as mentioned in this post,
setResolutionObject(<resolution>) never works for me. Do we need to validate with status or transition for this?
Can someone please share some idea on this.
Hello Sahan,
You can configure a post function in your workflow to property set a resolution value in your issue when you transition it to the "Done" Status. These are the steps:
- Navigate to your project > Project settings > Workflows > Click to edit your project workflow(s)
- On diagram mode, click on the transition that leads to the "Done" status (The last status of your workflow)
- In the right menu, Click post functions > configure the post function Update issue field to set a value for the resolution field
For more information about the resolution field, check this documentation:
How to edit the resolution of an Issue
Let us know if this information helps.
