This is my scenario:
I am closing an issue with groovy and I need to set the resolution to the issue. I don't want to use a post function because the issues being closed are the result of a JQL.
def query = ..... //query that returns issues
def user = userManager.getUserByName(//some user)
def results = searchProvider.search(query, user, PagerFilter.getUnlimitedFilter())
def issues = results.issues.collect {issueManager.getIssueObject(it.id)}
def issueResolutionConstant = constantsManager.resolutions.findByName("Done")
IssueInputParameters param = issueService.newIssueInputParameters();
issues.each{ issue ->
//I then have code that checks if the transition is valid which works and changes the status to "Complete"
param.setResolutionId(issueResolutionConstant.id) //THIS IS WHAT I NEED HELP WITH
@Vivian Escalante you'll want to use something like this
import com.atlassian.jira.component.ComponentAccessor import com.atlassian.jira.config.ResolutionManager def resolutionManager = ComponentAccessor.getComponent(ResolutionManager) if (! issue.getResolutionObject() ) { issue.setResolution(resolutionManager.getResolutionByName("Done")) }
Where are you trying to execute this script?
